Bottle, how big of a shot should I run?
Old Oct 12, 2005 | 01:00 PM
Pony_Fed95's Avatar
Default Bottle, how big of a shot should I run?
Ok, so I have a B20/vtec eg hatch. Set up is as follows:
PR3 Head:
P&P
Crower stage 3's
Crower valve springs
Crower Retainers
Crower Valves
AEM Cam gears
Skunk 2 Pro Series I/M
RC 310 injectors
GE Head studs
Block:
Stock with ARP rod bolts
GSR Water pump
ITR oil pump
GSR oil cooler
The car will be tuned on Hondata on the 22nd.
I just picked up a Full ZEX kit for $200. How big of a shot would you guys run through it? I was thinking just a 50-55..... or
Old Oct 12, 2005 | 09:49 PM
Pony_Fed95's Avatar
bumpo
Old Oct 12, 2005 | 09:55 PM
accorse07's Avatar
Default Re: (Pony_Fed95)
wait for the hondata to be tuned with the zex kit...
Old Oct 12, 2005 | 10:32 PM
Pony_Fed95's Avatar
Default Re: (accorse07)
sorry, thats what I was implying. It will be tuned on the 22nd then i will be spraying on it. I am thinking a 50 shot will be good enough. But could it take a 75shot?
Old Oct 14, 2005 | 06:28 AM
Mista Bone's Avatar
D Tranny Guru
it will take 100-125 shot............
I ran 100 shot on my puny D16Z6 SOHC......
Old Oct 14, 2005 | 07:21 AM
f22btwincam's Avatar
Default Re: (Mista Bone)
if you're gona tune it on nitrous then you could take it to a 150 direct port thats what my buddy has done on his b20v. it all depends on your tune how long your motor will put up with nitrous
Old Oct 14, 2005 | 08:40 AM
LSVTEC 91 Civic's Avatar
Banned
Tuning is the key to a reliable nitrous setup.. Hopefully you have a wet kit.
Old Oct 14, 2005 | 08:50 AM
f@sth@tch89's Avatar
Default Re: (LSVT3K 91 C1V1C)
this post is in the wrong forum...Forced induction and all motor do not mix!
go to https://honda-tech.com/zeroforum?id=16
Old Oct 14, 2005 | 11:52 AM
Pony_Fed95's Avatar
nitrous isnt forced induction tho
Pony_Fed95's Avatar
anyways, can I tune it for nitrous with a zex smart kit?
Old Oct 14, 2005 | 02:15 PM
ericrx_88's Avatar
i believe hondata s200 have nos control if thats what you have
Old Oct 14, 2005 | 07:24 PM
drdisco69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pony_Fed95 &raquo;</TD></TR><TR><TD CLASS="quote">nitrous isnt forced induction tho</TD></TR></TABLE>
Yes it is. If 1500psi isn't forced, I don't know what is. It certainly isn't naturally aspirated, that's for sure. Go try to run an NA class and tell them you have nitrous.
Old Oct 14, 2005 | 09:16 PM
Mista Bone's Avatar
D Tranny Guru
first off, it's not 1500 psi, only 900-1000.......
going over 1000 psi is asking for troubles.....
while not "forced induction" which indicates pressure is added, nitrous is a "power adder" and bumps you out of NA class.
Old Oct 15, 2005 | 08:49 AM
1700anddroping's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote">first off, it's not 1500 psi, only 900-1000.......
while not "forced induction" which indicates pressure is added, nitrous is a "power adder" and bumps you out of NA class.</TD></TR></TABLE>
your right about the 1500......somebody asks...whats that cracking sound coming from your car...oh thats my bottle fixing to explode...no biggie.
going over a 1k is asking for trouble......NOT IF YOU KNOW WHAT YOUR DOING....THAT BEING SAID...i have sprayed up to 1350 psi.
just look at some of the threads i have posted in"the starter of this thread" or if you need help just pm me or email at nitrousballa@twlakes.net
harv
greeneg2.0
Aug 24, 2008 06:58 PM
hbboostman
14
Dec 24, 2007 08:32 AM
Amped
Aug 27, 2006 09:56 AM
scUba-stEve
14
Oct 14, 2004 10:17 AM
