Radiator leaking!
Old Oct 12, 2005 | 12:53 PM
Utilitarian's Avatar
Default Radiator leaking!
Have you guys experienced your radiators leaking along the top where the silver trim is? About an hour ago I begin to see trace amounts of white smoke along the roof line and pull over to find that the bottom splash shield is collecting coolant via a small leak along the top of the radiator. Dammit!
Next question, would Len be the best source from an OE replacement or is there another brand I may want to check out. BTW, the car is stock and I race DS in auto-x. Immediate responces would be greatly appreciated.
thanks a mil!
Pissed again in NC,
Matt
Old Oct 12, 2005 | 12:56 PM
Dave_B's Avatar
Oh yeah everyone I've owned has done this. It happens where the metal meets the plastic. I would recommend getting an all metal one so it doesn't happen again in the future. I used a Modine on my GS-R.
Old Oct 12, 2005 | 01:01 PM
Eva01's Avatar
This is a common problem for G3 tegs, it happened to me with my previous GSR. When I replaced it, I got an aluminum radiator just so the problem would not reoccur. Fluidyne is the brand I went with. Now my brother has the car and no complaints yet.
Old Oct 12, 2005 | 01:11 PM
Booker's Avatar
Banned Duplicate Account
Default Re: Radiator leaking! (Utilitarian)
there is some one in the sponser forums that sells direct replacement Rads, take a look. Just a thought.
found some links:
https://honda-tech.com/zerothread?id=1400560
https://honda-tech.com/zerothread?id=1036108
https://honda-tech.com/zerothread?id=1372096
Old Oct 12, 2005 | 01:30 PM
Default Re: Radiator leaking! (Booker)
Thanks guys! Isn't it funny how you learn about various parts only when they get FUBAR'ed!
Old Oct 12, 2005 | 01:31 PM
Dave_B's Avatar
That's the way it tends to happen
Old Oct 12, 2005 | 02:05 PM
redGSRguy's Avatar
Default Re: (Dave_B)
My Fluidyne went in nice, but the stock fans didn't fit in. Too bad FALs cost so much .
Old Oct 12, 2005 | 03:16 PM
KOALA YUMMIES's Avatar
Default Re: (redGSRguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redGSRguy &raquo;</TD></TR><TR><TD CLASS="quote">My Fluidyne went in nice, but the stock fans didn't fit in. Too bad FALs cost so much .</TD></TR></TABLE>
The one on the passenger side, the bigger one bolts right up, if its a 94-01 Integra fluidyne going into a 94-01 integra itll bolt up, unlike the Koyos the Fluydines have provisons for both the Showa and Denso fans. The A/C fan will not bolt up though.
Old Oct 12, 2005 | 09:34 PM
HondaRS's Avatar
Default Re: (KOALA YUMMIES)
I have the same problem with my radiator on my 94 RS.
If i buy a Fluidyne do I need a to buy a different A/C fan?
Which radiator can I buy without having to replace anything else? Any help would be greatly appreciated.
Thanks
Old Oct 12, 2005 | 10:40 PM
redGSRguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KOALA YUMMIES &raquo;</TD></TR><TR><TD CLASS="quote">The one on the passenger side, the bigger one bolts right up, if its a 94-01 Integra fluidyne going into a 94-01 integra itll bolt up, unlike the Koyos the Fluydines have provisons for both the Showa and Denso fans. The A/C fan will not bolt up though. </TD></TR></TABLE>
Well on mine the top bolted up, and i had to modify the bottom to make it fit. Then I basically had to cut 1/2 of the fan shroud(sp?) to get it to fit in. I'm looking to get one of those slim fans once it get hot again for the a/c side. Unless I find someone selling their flexalites for cheap.
Old Oct 13, 2005 | 04:31 AM
jond's Avatar
Just had mine replaced under warantee
Old Oct 13, 2005 | 07:21 AM
p nut's Avatar
My OEM took a dive at 90k mark. I'd just get another one, which will last you another 90k. That'll cost you $100. How much are Fluidyne's? $300? Being stock, just stick with OEM or a generic radiator. No need for an all metal one, IMO.
Old Oct 13, 2005 | 07:25 AM
Dave_B's Avatar
Default Re: (P Nut)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P Nut &raquo;</TD></TR><TR><TD CLASS="quote">My OEM took a dive at 90k mark. I'd just get another one, which will last you another 90k. That'll cost you $100. How much are Fluidyne's? $300? Being stock, just stick with OEM or a generic radiator. No need for an all metal one, IMO.</TD></TR></TABLE>
The modine all metal one is only 130. I'd personally go with that and then forget about it. But that's just me.
Old Oct 13, 2005 | 07:31 AM
Larkin W.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Utilitarian &raquo;</TD></TR><TR><TD CLASS="quote">Thanks guys! Isn't it funny how you learn about various parts only when they get FUBAR'ed!
Happened to me too about 6 months ago. Must be about that time for an 8 yr old car
Old Oct 13, 2005 | 07:54 AM
Default Re: Radiator leaking! (Larkin W.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Larkin W. &raquo;</TD></TR><TR><TD CLASS="quote">
Happened to me too about 6 months ago. Must be about that time for an 8 yr old car </TD></TR></TABLE>
Yeah that's the excuse I'm going with to justify dropping $300 on a non-performance item.
I think I'll be going with the OEM just for piece of mind, fitment, and Solo 2 compliance.
Thanks for all the info Dave B.
Dave_B's Avatar
NP fool.
Old Oct 30, 2005 | 03:42 PM
Dave-ROR's Avatar
Happened to me friday night.
Only leaking at night in the "cold" florida nights we've had lately. during the day I can't detect ANY leaking.
Any all metal solutions that work with the stock fan without too much modifying of the fan brackets/etc?
Otherwise stock for me I guess
Old Oct 30, 2005 | 05:57 PM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Utilitarian &raquo;</TD></TR><TR><TD CLASS="quote">Next question, would Len be the best source from an OE replacement or is there another brand I may want to check out. BTW, the car is stock and I race DS in auto-x. Immediate responces would be greatly appreciated.
Len, or a racer that has replaced his radiator for a upgraded one. You might want to ping people you know that have been stripping OEM cars, or look through the F/S ads. I sold my OEM one a year ago.
zero2hero
Jan 30, 2007 08:49 PM
ejmatzell
Dec 12, 2006 11:32 AM
dynastix9
Dec 18, 2005 06:33 AM
FD3S
Dec 15, 2005 08:37 AM
eastsideATX
Jul 6, 2005 02:56 PM
