i got a cluster problem??any advice??
Sounds like you have a bad ground or a shorted wire. Bad grounds can cause all sorts of weird evil problems that are hard to track down. Pull it out and check for any obvious open wires or rusty/corroded grounds
Yea pull the cluster out and look at the back of it, there is a circut board and lots of plugs/harnesses just check them out and make sure none are corroded or frayed. Then trace the wires back and check out the grounds, those will be the ones bolted to a metal part of the car.
MTarry
11
Jan 15, 2013 06:46 PM
JDMforlifeOH
14
Jun 11, 2009 09:36 PM
mawkiemarc
15
Apr 19, 2005 09:24 AM
