why did my exhaust spit out black stuff?
Old Oct 12, 2005 | 10:33 AM
Tealeg88's Avatar
Default why did my exhaust spit out black stuff?
I was driving my eg(with a gsr) and I was going about 50mph and this car next to me was messing around with me so I dropped it into second gear and black stuff came out of the exhaust. Is this bad? Could it be restricting my power? Or am i just a dumbass?
Old Oct 12, 2005 | 10:38 AM
Luserkid's Avatar
Default Re: why did my exhaust spit out black stuff? (Tealeg88)
its normal.
Old Oct 12, 2005 | 11:38 AM
Lmgrcivic's Avatar
Default Re: why did my exhaust spit out black stuff? (Luserkid)
your just running alittle rich
Old Oct 12, 2005 | 11:54 AM
SE7EN3S's Avatar
Was your car sitting for a extended period of time prior to this? Many times the condensation and carbon buildup in your exhaust will shoot out when you step on it like that.
Be thankful it wasn't white smoke = Possible head gasket
Old Oct 12, 2005 | 12:01 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: why did my exhaust spit out black stuff? (SE7EN3S)
i posted this in another thread. it should hold true to you also:
" byproducts of combustion are hydrogen and oxygen. they make water. if you were running fat at one time, there may be some carbon built up in your exhaust. good combustion sometimes will cause water to come out of your tailpipe emmissions. this outgoing water sometimes grabs the carbon and takes it out the tail pipe. dont worry about it. "
Old Oct 12, 2005 | 12:13 PM
eL's Avatar
eL
Going INTO 2nd at 50 is stupid.
Old Oct 12, 2005 | 12:17 PM
mwieczorek43's Avatar
Default Re: (eL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eL &raquo;</TD></TR><TR><TD CLASS="quote">Going INTO 2nd at 50 is stupid.</TD></TR></TABLE>
I was thinking that same thing.... but i don't have a gsr tranny, so i don't know how the gears are
Old Oct 12, 2005 | 01:36 PM
Tealeg88's Avatar
Default Re: (mwieczorek43)
my gear ratios are pretty long, would it still put to much stress on the car? I usually have till 70 in second.
Old Oct 12, 2005 | 01:44 PM
Tony_EM1's Avatar
Default Re: (eL)
Old Oct 12, 2005 | 01:45 PM
Deemeetree's Avatar
Electrician
Almost all DOHC VTEC engines I see run on WOT do spoot a little black ****.
Old Oct 12, 2005 | 01:48 PM
Tealeg88's Avatar
Default Re: (Deemeetree)
ok i wonn't go in second at 50 anymore, but what does it mean when the engines run on WOT!
Old Oct 12, 2005 | 01:49 PM
Deemeetree's Avatar
Electrician
Wide Open Throttle.
Old Oct 12, 2005 | 01:53 PM
Tealeg88's Avatar
ok cool, but than should i get my car tuned to run a little leaner since it seems to be running rich. I do have a chipped p28 that hasnt been tuned yet, along with the skunk2 intake mani.
M Allen Duncan
11
Mar 21, 2018 05:52 PM
vsikwit
Sep 14, 2010 09:00 PM
rod64
Oct 29, 2006 06:47 PM
ej2rider
23
Jul 16, 2005 03:36 PM
d16efsedan
Apr 27, 2005 09:07 AM
