D15B INTO A 92 VX ???? 5 Wire o2 to a 4 Wire?
Old Oct 12, 2005 | 08:54 AM
VXJDMHATCH's Avatar
Default D15B INTO A 92 VX ???? 5 Wire o2 to a 4 Wire?
hey everyone me again! ... had problems with the stock vx motor wich i wish i could keep b.c it gives great gas milage ... but too much of a head ache! sooooooooooo .... im going to get a good deal on this d15b ... 30 hp more almost as good gas milage wich isnt bad .... and i need help! as much as possible ..... now the stock vx motor is a 5 wire O2 sensor .... wich is very rare ... and the d15b is a 4 wire ... which wires do i need to switch around or is it a striaght plug and play!???????
Old Oct 12, 2005 | 12:12 PM
kodirtysi's Avatar
Default Re: D15B INTO A 92 VX ???? 5 Wire o2 to a 4 Wire? (VXJDMHATCH)
bump
Old Oct 12, 2005 | 12:22 PM
howangseg's Avatar
Default Re: D15B INTO A 92 VX ???? 5 Wire o2 to a 4 Wire? (kodirtysi)
bump cus i have a d16z6 in a vx and need to know how to do 5>4 wire o2. please help a brother out. haha peace
Old Oct 12, 2005 | 12:37 PM
dwnthehatch's Avatar
LOCATE THE 6 PIN PLUG BELOW ON THE PASS. SIDE VX SHOCK TOWER
The wires are in the following order:
ORG/BLU BLU/GRN WHT/BLK
BLU/YEL WHT/BLU YEL/WHT
REMOVE THE FOLLOWING WIRES FROM THE 6 PIN VX PLUG
ORG/BLU - O2 SENSOR
LOCATE THE 10 PIN PLUG PICTURED BELOW THAT IS ON THE VX SHOCK TOWER
BRN/BLK EMPTY BLK/RED
ORG WHT ORG/BLU WHT/BLU
BLU/GRN BLU/YEL EMPTY
REMOVE THE RUBBER PLUG FROM THE TWO UNUSED SOCKETS
INSERT THE ORG/BLU (O2 SENSOR) WIRE INTO THE SOCKET BETWEEN THE BRN/BLK WIRE AND THE BLK/RED WIRE. (TOP CENTER SOCKET IN PIC)
You are done.
Old Oct 14, 2005 | 07:18 AM
VXJDMHATCH's Avatar
woooooooohooooooooooooooooooooooooooo solved our problems .... dwnthehatch ....
Combustion Contraption
May 30, 2011 10:50 AM
mjshealy
Jul 1, 2010 05:44 PM
rdt
Nov 15, 2006 04:41 PM
92b16vx
May 22, 2003 02:45 PM
Houston Hatchback
Apr 23, 2003 05:17 PM
