crx hf swap
Old Oct 12, 2005 | 08:20 AM
enve55's Avatar
Default crx hf swap
what do i all need to change from the hf model to swap in the si motor from another crx?
Old Oct 12, 2005 | 08:27 AM
k e v i n's Avatar
Default Re: crx hf swap (enve55)
this might help but i dont know if its the same...
https://honda-tech.com/zerothread?id=1396895
Old Oct 12, 2005 | 09:27 AM
enve55's Avatar
Default Re: crx hf swap (k e v i n)
yeah.. that is for DP swap but the hf model isnt DP but i know the swap parts are different for a B-series then it is for a si swap like the knuckles im jw what i will need or swap different parts
Old Oct 12, 2005 | 02:06 PM
d16vtecx's Avatar
pm6 ecu
si motor w/manifolds
you can keep your hf trans but it is geared for fuel economy not performance
Old Oct 12, 2005 | 03:42 PM
k e v i n's Avatar
Sorry, I don't really know much about the crx trim levels... just thought maybe that would help
Old Oct 13, 2005 | 09:37 PM
b20vtec crx's Avatar
i own a HF my first swap was indeed the d16a6(si motor)
1. the engine is a drop in.
2. injectors and engine harness you can use.
3. ecu will need to be changed to pm6(si ecu)
4. if you use the HF tranny u can retain the same axles, if you use the Si tranny you will need to change out the axles, and hubs to either dx or si. or even better integra.
Old Oct 13, 2005 | 09:43 PM
gnar kill's Avatar
Default Re: crx hf swap (b20vtec crx)
I got a set of si hubs and knuckles...if you need em let me know
Old Oct 13, 2005 | 10:49 PM
dvang's Avatar
Default Re: crx hf swap (gnar kill)
u can use the si tranny and still retain your hf hubs/axles. if you swap the hubs to si than you need si axles
Old Oct 14, 2005 | 05:07 PM
Default Re: crx hf swap (dvang)
HF axles are not compatible to SI tranny UNLESS you change the inner shaft to SI. WHY bother doing that?? cheaper? your own opinion!
downfalls of using the HF tranny with SI motor=longer gears, but clutch and tranny wont last long.. BEEN there done that.
dont believe what whats his face says:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dvang &raquo;</TD></TR><TR><TD CLASS="quote">u can use the si tranny and still retain your hf hubs/axles. if you swap the hubs to si than you need si axles</TD></TR></TABLE>
trust me
Old Oct 14, 2005 | 05:59 PM
dvang's Avatar
"shrugs" ive done it and it worked so whatever
Old Oct 15, 2005 | 06:19 AM
are you sure you even had a HF? sure it wasnt a DX?
Old Oct 15, 2005 | 10:21 AM
dvang's Avatar
the inner sides which plugs in the tranny is the same on all axles. its the outer part of the shaft that goes in the hub on hf/4spd civics that are smaller.
Old Oct 15, 2005 | 12:19 PM
A HF transaxle has "5" gears. the inner shaft would need to match the following:
si or dx = si or dx
hf = hf
the outter shaft as follows:
si or dx = si or dx
hf = hf
does that make you feel smarter?
the combos
hf transaxle + hf hub = hf axle
si or dx transaxle + si or dx hub = dx or si axle
si or dx transaxle + hf hubs = si or dx inner shaft and hf outter shaft
hf transaxle + si or dx hubs = hf inner shaft and si or dx outter axle.
im done with this topic obvious you havent swapped much of anything out in your lifetime.
Old Oct 15, 2005 | 01:24 PM
dvang's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20vtec crx &raquo;</TD></TR><TR><TD CLASS="quote">A HF transaxle has "5" gears. the inner shaft would need to match the following:
si or dx = si or dx
hf = hf
si or dx = si or dx
hf = hf
the combos
here you go genius. go to the link. your answer is there. we know your immense knowledge is BS now.
http://ef-honda.com/main/viewt...47862
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotime &raquo;</TD></TR><TR><TD CLASS="quote">so b20vtec crx was a wedge?
and by wedge i mean the simplest of all tools.</TD></TR></TABLE>
Modified by dvang at 4:39 PM 10/15/2005
Old Oct 15, 2005 | 02:22 PM
dvang's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20vtec crx &raquo;</TD></TR><TR><TD CLASS="quote">hey for ur information i actually have that b16 taken out and have a b20vtec-turbo'd t3/t4 50trim
it was a simple question to whether or not they bolt on. and if they didnt if i would have to weld two fenders together...just some helpful 411 before i go out and cut perfectly good fenders.
then all of a sudden because i had a turbcharged b16 with et times at 12.7 at 126 mph you guys try and smash the competition. i dont get it. school over for you nerds?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tokes1320 &raquo;</TD></TR><TR><TD CLASS="quote">
You don't have to make anything up, but you did, so why are you still posting here? 2 weeks ago you had a GSR block/head and a B16 block with a T25 turbo and you wanted to know how you could make the lowest compression ratio setup, and now you have a supposedly built motor with a T3/TO4E 50-trim running 12's @ 125? Bitch please. It's pretty sad when at the age of 24 you need to make **** up about how fast your cheap 80's economy car is to impress a bunch of 18 year olds on a message board so they don't flame your shitty taste in cars.</TD></TR></TABLE>
your bs also goes into your car i see .. in this thread you stop posting and since than had to change your name. your credibility you may now proceed to drive your 64hp car off a cliff and stop postin.
edit to add thread.. https://honda-tech.com/zero...98154
Old Oct 15, 2005 | 03:03 PM
your a ******* moron! u dont even know how to swap a motor that comes in a USDM vehicle! and your tooo ******* cheap to buy a REAL honda motor with TWO cams and not prehistoric like what u only have enough for...how much is it...150$?
now about ur comment about me changing my name...
here goes..
yeah i asked a simple question about fenders bolting up. it was a question in a cosmetic forum! now if u must know. my name was changed for updating my information with a name that BEST suits the money i have invested over the years into my car. if you look at my crx. compared to what your working with, u can say i havent' been cheap. smart guy. had nothing to do about someone critisizing my questions because thats how people learn. u ask dumb questions about swaping a DIRECT bolt in motor and need the advice from others because ur soo lame and cant read a manual!
FOOL! know what your asking and know this.. you dont know what your talkin bout! cheap skate
Old Oct 15, 2005 | 03:05 PM
one person reposts with yes and you take his word for it. lame ur little "trying to prove a point" didnt prove anything
Modified by dvang at 4:39 PM 10/15/2005</TD></TR></TABLE>
Old Oct 15, 2005 | 03:14 PM
dvang's Avatar
i take the word of the ef site over a guy who likes to BS about his imaginary car.
Old Oct 15, 2005 | 03:16 PM
dvang's Avatar
here goes..
FOOL! know what your asking and know this.. you dont know what your talkin bout! cheap skate</TD></TR></TABLE>
your pictures prove your lies. t3/t4 looks like a lil t25 from a dsm to me.. and my car has four cams.. that doesnt metter to me but may be you can go buy 2 more and tape it on. my car sucks just not as bad as your hacked car tho. you still suck *** and the point now is your a bad liar.
i have no use for your honda motor sorry.. idont feel a need to compare my car with yours because like my ***** its better.
Modified by dvang at 6:29 PM 10/15/2005
Old Oct 15, 2005 | 03:29 PM
t3/t4 on the b20?? no t3/t4 was on the b16a. t25 from 99 eclipse is on b20z. get it right. that post was before i had the engine changed out.
now my imaginary car??
lmfao get real loser.
yeah what!
Old Oct 15, 2005 | 03:36 PM
dvang's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20vtec crx &raquo;</TD></TR><TR><TD CLASS="quote">t3/t4 on the b20?? no t3/t4 was on the b16a. t25 from 99 eclipse is on b20z. get it right. that post was before i had the engine changed out.
yeah what!
so the t25 is on the b20 you have lol.. if your t3/t4 existed why would you downgrade to that tiny turbo
Old Oct 15, 2005 | 03:39 PM
stepped down to spool quicker to try and prevent boost lag
Old Oct 15, 2005 | 03:41 PM
b20 has thin cylinder walls low compression
Old Oct 15, 2005 | 04:12 PM
dvang's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20vtec crx &raquo;</TD></TR><TR><TD CLASS="quote">stepped down to spool quicker to try and prevent boost lag</TD></TR></TABLE>
sure because you never stepped up to another turbo don't need to keep digging your own grave here
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20vtec crx &raquo;</TD></TR><TR><TD CLASS="quote">b20 has thin cylinder walls low compression</TD></TR></TABLE>
your vast knowledge told you that adding a vtec head to a b20 block lowered the compression. actually it goes up dumb ***.
you dont need to question my knowledge but your own. i can admit i dont know everything but the posts your making seems to point to the fact that i know more than you.
please keep posting your just adding to all the facts that shows how mentally challeged you are.
message from the genius with his dunce hat on sitting at his computer
(3:22 PM 10/15/2005) b20vtec crx: your an idiot!
Old Oct 15, 2005 | 04:19 PM
HondaCivicSiR1's Avatar
(3:22 PM 10/15/2005) b20vtec crx: your an idiot!</TD></TR></TABLE> now girls fight nice.lol
