Ground Control coil question
Old Oct 12, 2005 | 07:20 AM
SE7EN3S's Avatar
Default Ground Control coil question
I feel retarted for asking this, but I can't find the answer and I'd rather be safe than sorry. I picked up the GC's on ebay and I am not sure which is which. -- They were packed seperatly.
Can you guys let me know which sleeves are the fronts and rears? i.e. tall sleeve or short sleeve. And also which spring is which i.e. again, tall spring and short spring.
Thanks and sorry for the idiot questions -- PS these are for a 99 EK
Old Oct 12, 2005 | 07:24 AM
drktorn's Avatar
Default Re: Ground Control coil question (SE7EN3S)
the short in the front, tall in the back. if remember right. you should be able to find a "F" or "R" stamped on the spring. correct me if im wrong someone.
Old Oct 12, 2005 | 07:31 AM
SE7EN3S's Avatar
Default Re: Ground Control coil question (drktorn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drktorn &raquo;</TD></TR><TR><TD CLASS="quote">the short in the front, tall in the back. </TD></TR></TABLE>
Is that 'short' for both sleeve and spring?!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drktorn &raquo;</TD></TR><TR><TD CLASS="quote">you should be able to find a "F" or "R" stamped on the spring. correct me if im wrong someone. </TD></TR></TABLE>
I looked for F and R but only found part #'s, which wern't on GC's website.
Thanks
Old Oct 12, 2005 | 07:46 AM
drktorn's Avatar
if i "remember" its short with short. long with long
Old Oct 12, 2005 | 07:52 AM
Slosc2's Avatar
When you get the car in the air, and the tires off, it will be self explanatory. I believe the longer springs and sleeves go up front, and the short sleeves and springs in the rear.
Old Oct 12, 2005 | 08:28 AM
tr0n9h's Avatar
Default Re: Ground Control coil question (Slosc2)
long front short rear. alot of weight in front due to engine, so u will use the bigger one in front.
Old Oct 12, 2005 | 08:36 AM
Crazydave's Avatar
Default Re: Ground Control coil question (tr0n9h)
there is no front or rear markings on the springs since they are mass produced for a lot of applications.
Short sleeve goes in the front.
the short spring goes in the rear
Old Oct 12, 2005 | 09:13 AM
EK k kay's Avatar
Default Re: Ground Control coil question (Crazydave)
Long spring w/ short sleeve in the front. Short spring with long sleeve in the rear. Look at the numbers on the springs. You want the stiffer springs in the front since these are OTS ground controls. 44 x 5.71 = 250lb rear springs. 58 x 5.71 = 330lb front springs. That's the same set and spring rate I use on my 99 civic hatchback.
Old Oct 12, 2005 | 09:17 AM
SE7EN3S's Avatar
Default Re: Ground Control coil question (EK k kay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK k kay &raquo;</TD></TR><TR><TD CLASS="quote">Long spring w/ short sleeve in the front. Short spring with long sleeve in the rear. Look at the numbers on the springs. You want the stiffer springs in the front since these are OTS ground controls. 44 x 5.71 = 250lb rear springs. 58 x 5.71 = 330lb front springs. That's the same set and spring rate I use on my 99 civic hatchback.</TD></TR></TABLE>
Awsome, thanks. I obviously haven't got them on the car yet, but how are they on your hatch?! You like?
Old Oct 12, 2005 | 09:25 AM
EK k kay's Avatar
I have them paired with a set of kyb agx shocks. They ride very well for a budget street setup.
Old Oct 12, 2005 | 09:32 AM
kaiba's Avatar
The short on is in the rear.
Old Oct 12, 2005 | 09:43 AM
SE7EN3S's Avatar
Excellent. I am pairing them with Konis. I had Nuespeeds with stock shocks = boooo I can't wait.
Old Oct 12, 2005 | 09:46 AM
EK k kay's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SE7EN3S &raquo;</TD></TR><TR><TD CLASS="quote">Excellent. I am pairing them with Konis. I had Nuespeeds with stock shocks = boooo I can't wait.</TD></TR></TABLE>
Make sure you contact ground control and get the baby sleeves which are used on the koni's.
Old Oct 12, 2005 | 09:52 AM
SE7EN3S's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK k kay &raquo;</TD></TR><TR><TD CLASS="quote">Make sure you contact ground control and get the baby sleeves which are used on the koni's.</TD></TR></TABLE>
Yeah got those!! Thanks
BTW: When you installed, did you find that the springs don't sit TIGHT on the shock like non-coil overs? ( You know how you have to compress the stock spring before you remove the upper mount) -- Does that make sence?
FastLife617
Suspension & Brakes
Mar 5, 2008 07:11 PM
bosco500
Jun 8, 2005 05:32 AM
deviant1
May 1, 2004 03:33 PM
Seedc2
Jun 25, 2003 09:47 AM
SkyeC
13
Jan 17, 2003 07:23 PM
