Code 14 - bad idle with hondata - even change the IAC???
Old Oct 12, 2005 | 04:20 AM
Paluce's Avatar
Default Code 14 - bad idle with hondata - even change the IAC???
Here's the problem... The car is throwing a code 14. The car runs fine when I'm giving it gas (greater than about 6% duty cycle). But idles like ****. Revs drop too quickly during shifts...
I have a Hondata S200b and JRSC.
Last night I changed to Entire Throttle body. IAV valve, TPS sensor... everything to see if it was just the IAC. I started it, and same problem... Terable idle, almost stalls, code 14. I Re-set the ECU, the code went away for 10 sec or so, and back on, just like before.
The wierd thing is, if I turn off the car, the code gets erased... (Shows on the dataloger), then shortly after it pops back on.
I'm guessing it's a problem with the Hondata or ECU making something throw this code? Any idea's?
Old Oct 12, 2005 | 05:43 PM
Paluce's Avatar
anyone???
Old Oct 14, 2005 | 04:07 AM
Paluce's Avatar
Problem solved!
It turned out to be the IAC two pin connector wire that was rubbing against the PCV line. It wore threw since the IAC was moved for the JR instalation.
Everything is back to normal.
Nfurno
Sep 1, 2004 12:42 PM
smokinsi
Jul 18, 2004 05:09 PM
crxY-49
Jul 1, 2004 06:26 PM
project dc2
Jan 19, 2004 07:18 PM
