K vs B --- What do you think?
Old Oct 12, 2005 | 04:19 AM
Screamer's Avatar
Default K vs B --- What do you think?
Here is my dilemma. I have an EG HB that I use for track events. I am thinking of putting a new engine in it. And this is what I can’t decide between:
Option 1:
Head:
Toda Spec D cams
Toda valvetrain
Toda ITB’s
P&P
Block:
B16 block sleeved to 84mm and B17 crank – basically high reving 1800cc engine
12.5:1 cr with forged rods
Strengthened and balanced for high reving ability
Tranny:
ITR with 4.9 final drive
And all the other bits and pieces to make this thing run in the 11K rpm range.
Option 2:
K20 (Type R sepc) Stock for now.
So what do you guys think?
All opinions are welcome.
Old Oct 12, 2005 | 07:46 AM
boxattack's Avatar
Default Re: K vs B --- What do you think? (Screamer)
well even though im considererd a newbie due to my post. I would getthe k series its going to last longer than the b.
Old Oct 12, 2005 | 08:10 AM
hcarcrx's Avatar
k motor all the way
Old Oct 12, 2005 | 08:17 AM
Player5530's Avatar
if you looking for a track car get the built B motor. Its a track car, the motor lasting to 100,000 miles and more is not an issue to consider
Old Oct 12, 2005 | 08:18 AM
EK9-Stealth's Avatar
boxattack, what do you mean it will last longer? Its newer dont mean it will last longer; how long do you plan on living? Anything before B series motor is made for cutting grass. A B series can make over 200whp easy, so do you think in the future everyone would need a 300+whp car? I do agree with going with the K though. Type R power is the ****. Go with the R, kpro with a good header.
Old Oct 12, 2005 | 08:22 AM
Sahwn's Avatar
that is a pretty tough decision. I would revert to saying money but I don't know if that is an issue. However, installing the K will be LOTs more work than then B. I would go with the B and wear that Bitch out then put in the K. Sounds like the B will out perform the K anyways. My 2 cents.
Old Oct 12, 2005 | 09:20 AM
Nikos's Avatar
Default Re: K vs B --- What do you think? (boxattack)
Your answer lies within your question.. You are comparing a fully built B vs a stock K. The total $$ bill for the B series motor will be way over 10K for sure unless you get special pricing.With the same amount of money, you can be making close to 300whp on a kseries all motor.
Let me give you an example.. Last week I bought a TSX motor that came from a car that caught on fire...
Here's the motor I received
paid $500 for it...
I took it apart and I am sending it to ERL performance to get 89mm sleeves
My plans are stock 89mm crank, 89mm pistons with around 12.5-13.0 compression, 52MM TWM ITBS, and cams with stock head. In my opinion this is going to make at least 270whp with hondata K pro.
Sleeves $1500
ITBS $2000
cams +valvetrain $1400
pistons $500
rods $800
misc like type s pump, ACL bearings $300
Average high retail price for all these parts so you get an idea.
New accord bare blocks k24a go for $500 from your honda dealer. Type s heads go around $1000 and 6 speed transmissions go for $1000 + $800 quaife LSD.
When adding parts like sensors, gears, chain, water passages, hoses, oil pans, wire harnesses, chain covers, bolts, alternator, starter, etc... YOu are looking at around 9-10K and you still have to put it in the EG with mounts, axles, headers etc...
That is if you are looking for a K series all motor monster... So in my opinion, the b series combo you described will be as much if not more since the toda ITBS are $$$ on their own.
I was bored last night and played around with fitment to see what I need to cut to fit the ITBS
Old Oct 12, 2005 | 09:25 AM
fsp31's Avatar
Default Re: (EK9-Stealth)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK9-Stealth &raquo;</TD></TR><TR><TD CLASS="quote">Anything before B series motor is made for cutting grass. </TD></TR></TABLE>
That's a sig-line quality quote. But I don't understand...
To the original poster, are you set on that particular B series setup? 11k rpm's won't be reliable under any circumstances. Why the need to rev so high? What are your HP goals?
Old Oct 12, 2005 | 11:00 AM
909ER's Avatar
Default Re: K vs B --- What do you think? (Nikos)
Nikos, All that and using ACL bearings? Wouldnt you want a fully measured bearings for better clearance than just Universal bearings?
Or are you cutting the crank to compensate for the differences in clearance of each bearing.
Old Oct 12, 2005 | 11:46 AM
Nikos's Avatar
Default Re: K vs B --- What do you think? (909ER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 909ER &raquo;</TD></TR><TR><TD CLASS="quote">
Or are you cutting the crank to compensate for the differences in clearance of each bearing.</TD></TR></TABLE>
Exactly, ERL does this to all the K series blocks that get assembled and sleeved in house.
Check out the spec sheet on my last K24a block that was built last july. Forgive me if I erased the part numbers of the bearings but I cannot give out 100% of the recipe.. Only 99% of it
Check out the quality of work done by ERL performance. Excellent quality work and fast turnaround.. I believe it took them one day to get the pistons, rods, bearings and crank installed in the block. This is why I don't understand why people feel like they need to wait on someone for 12 month to install a damn piston in their block
Old Oct 12, 2005 | 04:18 PM
mark_is_gay's Avatar
if u need a motor now for ur race season then go with the b if not and u can wait a whyle then i guess go with the k
Old Oct 12, 2005 | 07:13 PM
trrbl1bmx's Avatar
Well, The K is here to stay, so I would say, go ahead and get it. I mean in a year there are going to be so many different routes you can take with the K. It definatley has potential. Most built B-series are making what the K makes stock. But thats just my $.02
Old Oct 12, 2005 | 08:49 PM
H2nr's Avatar
Default Re: (ilovemyef9)
My stock K with cams has take down many built H and B series engines. Hell just look at the difference in what the head flow. K all the way
Old Oct 13, 2005 | 01:10 PM
Screamer's Avatar
Default Re: (H2nr)
Interesting comments. Thanks for all the replies. The only thing that I am concerned with the K series engines is the rod strength ( I heard of the rods braking at high revs) and the smaller oil passages then the b-series ( this causing oil starvation on road racing engines). The two issues may be actually related, I am not sure. Any thoughts on this?
Old Oct 13, 2005 | 02:48 PM
civicross's Avatar
Default Re: (Screamer)
In regards to the oil problem I think if you have ERL do the machine work they have most of that figured out to the point that it isn't a problem anymore.
Old Oct 13, 2005 | 02:59 PM
bnut510's Avatar
Default Re: (civicross)
i got love for the b series, but k produces mad power plus its the new age.
Old Oct 13, 2005 | 04:45 PM
Televator's Avatar
Default Re: (bnut510)
If I had no specific preference for motors I'd go with a K. It's just the future and will be a good foot note in history when street driven N/A 4 cylinders made 300 HP. I just wish Honda made another series besides K. K is cool and all, but so were the B and H back in their day and I loved the options of going for different series and the friendly competition in between them.
However I do see that it's in Honda's finacial interest to stick to one series that retains many manufacturing similarities across all car lines.
Old Oct 13, 2005 | 08:00 PM
high_revs's Avatar
k
slick1851
20
Jun 27, 2012 06:54 AM
H22_cRX_Si
Feb 11, 2009 07:42 PM
an2ny888
Feb 21, 2008 05:17 PM
hrs-parker
15
Feb 17, 2008 10:17 AM
BigAl
Dec 16, 2004 11:17 AM
