fucked up idle
Old Oct 11, 2005 | 10:28 PM
Ur 2 Slow 4 J's Avatar
Default fucked up idle
my idle keeps going from 1500-3000. then it levels out at 2000. i replaced the cap and rotor, and replaced the throttle body gasket. i took carb cleaner and cleaned it out, plus i checked the throttle body for leaks. any other ideas?
Old Oct 11, 2005 | 10:32 PM
Luserkid's Avatar
Default Re: fucked up idle (Ur 2 Slow 4 J)
Did you try FITV or IACV?
Old Oct 11, 2005 | 10:40 PM
Default Re: fucked up idle (Luserkid)
what are those and where r they
Old Oct 12, 2005 | 07:17 AM
Orangedragone's Avatar
fuel filter?
Old Oct 12, 2005 | 07:24 AM
vtakvtrak's Avatar
Default Re: fucked up idle (Orangedragone)
FITV AND IACV are usually the problems... check for vaccum leaks too, mine does that to.. but not all the time, it does it very rarely but sometimes when im at a stop sign or stop light waiting to go it would surge from 1000 to 1500 rpm and go back down and up and down.
Old Oct 12, 2005 | 07:48 AM
vtecgod's Avatar
Yeap check the iac valve on the back of the intake.
Old Oct 12, 2005 | 08:34 AM
JDM-EJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">Did you try FITV or IACV? </TD></TR></TABLE>
ge_ej1
Jan 29, 2008 05:09 PM
Dirtfall
Feb 1, 2007 08:54 AM
jdmCivic925
Oct 25, 2005 02:37 PM
h22831
Jul 18, 2005 06:36 PM
Ti3d in
Nov 29, 2004 10:17 PM
