what size are ARP nuts?
Old Oct 11, 2005 | 09:10 PM
GSRCRXsi's Avatar
Default what size are ARP nuts?
i have the 9mm ARP rod bolts for b18c1 engines. i figured it was metric, but i guess it isnt. 11mm was a little lose, and 10 mm didnt fit.
is it 3/8" or something?
Old Oct 12, 2005 | 10:24 AM
GSRCRXsi's Avatar
Default Re: what size are ARP nuts? (GSRCRXsi)
i know somone has arp rod bolts in here.
Old Oct 12, 2005 | 10:34 AM
PURPLETERROR aka BIGMATT's Avatar
i used 11mm 12pt socket, worked fine
Old Oct 12, 2005 | 10:47 AM
GSRCRXsi's Avatar
Default Re: what size are ARP nuts? (PURPLETERROR aka BIGMATT)
yea 11mm fits but is kinda loose IMO.
AFAIK, ARP uses SAE, i just want to see if anyone else did it with SAE tools, the only thing that im comming up with thats inbetween 10 and 11mm is 13/32" which is eqivalent to like 10.3mm. is this the correct size?
Old Oct 13, 2005 | 08:31 AM
GSRCRXsi's Avatar
no one has done this with sae tiools?
Old Oct 13, 2005 | 08:43 AM
shamoo's Avatar
Will you make something up for me please?
Yes, as far as I know, ARP uses standard sizes. I know I used a standard size for my head studs (1/2 inch) and rod bolts. Unfortunately, I don't know what size it was. I forgot.
Can't you just try a size and see if it fits? I assume you have a set of standard sockets?
Old Oct 13, 2005 | 12:19 PM
GSRCRXsi's Avatar
Default Re: what size are ARP nuts? (shamoo)
i dont have a set of std. 12pt sockets. i have no use for them. im just gonna buy the individual sockets for this. 1/2" 12pt for the head studs, and whatever the size rod bolt nuts are.
Old Oct 13, 2005 | 12:42 PM
shamoo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRCRXsi &raquo;</TD></TR><TR><TD CLASS="quote">i dont have a set of std. 12pt sockets. i have no use for them. im just gonna buy the individual sockets for this. 1/2" 12pt for the head studs, and whatever the size rod bolt nuts are.</TD></TR></TABLE>
Yeah, you should actually get a set of standard ones. Never know when you'll need them.
Don't get a 12 point for the head studs. It's a 6 point bolt, and you don't want to risk stripping anything when you're messing with head bolts/studs. Also make sure it's a deep socket too. 6-point 1/2" deep socket for the ARP head studs =
Old Oct 13, 2005 | 06:22 PM
GSRCRXsi's Avatar
why would i use a 6 point 1/2" on a 12pt 1/2" bolt? thats asking to strip.
Old Oct 14, 2005 | 04:27 AM
shamoo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRCRXsi &raquo;</TD></TR><TR><TD CLASS="quote">why would i use a 6 point 1/2" on a 12pt 1/2" bolt? thats asking to strip.</TD></TR></TABLE>
ARP head stud bolts are 6 pt. At least that's what mine were.
Old Oct 14, 2005 | 07:53 AM
GSRCRXsi's Avatar
what engine were yours for? were yours bolts or studs?
mine are definitely 12pt. i just looked at them in the package to double check.
Old Oct 14, 2005 | 08:29 AM
shamoo's Avatar
Mine were head studs for a B18B. And the bolts that went on them were 1/2" 6 point. Sorry, didn't specify.
Old Oct 14, 2005 | 09:08 AM
GSRCRXsi's Avatar
yea mine are for a b18c
Old Oct 14, 2005 | 09:09 AM
GSRCRXsi's Avatar
anyway, this is way off topic.
back to the sie of the rod bolt nut. anyone know the correct sae size?
Old Oct 14, 2005 | 03:51 PM
NJIN BUILDR's Avatar
The ARP 9mm GSR rod bolts use a 7/16" 12 point socket.The ARP GSR head studs use a 1/2" 12 point socket.
Glenn
rick_rabies
Honda Fit
Aug 5, 2014 06:51 AM
ghg78
Sep 3, 2009 07:35 AM
Civic
Feb 27, 2005 03:01 PM
luckypon7
Jan 20, 2004 10:59 AM
