awhat cams are better for a all moter ls
Old Oct 11, 2005 | 05:50 PM
revteglsv's Avatar
Default awhat cams are better for a all moter ls
i need so help on chosing some cams for my all moter ls pleaz help
Old Oct 11, 2005 | 06:03 PM
Sam92Teg's Avatar
Default Re: awhat cams are better for a all moter ls (revteglsv)
Need some more info, you staying with stock compression, stock valve train?
Visit http://www.nonvtec.com/board/viewforum.php?f=8
Old Oct 11, 2005 | 06:04 PM
apok's Avatar
I went with Crower 62403 cams and Skung2 cam gears. It gives a great powerband. Some people say 62404 cams are good, but you'd need to get a higher compression piston set, or you won't see much gain over stock.
Also, with any cam you choose, you'll need tuning to get the full effect. I'm still waiting until I finish my Supra project, since my LS-T project failed.
Old Oct 11, 2005 | 06:11 PM
95lstegman's Avatar
Default Re: awhat cams are better for a all moter ls (apok)
404 is fine with stock c/r. it will make as much as raised c/r with 403's. then if you add c/r down the road you'll make way more than 403's ever will.
Old Oct 11, 2005 | 06:19 PM
revteglsv's Avatar
Default Re: awhat cams are better for a all moter ls (Sam92Teg)
well i made my 1.8 to a 2.0 i high comprestion pistons (arias) now i want to change my cams, cam gears and the retainers
Old Oct 11, 2005 | 06:28 PM
95lstegman's Avatar
definitely 404's for a 2.0L
torqueaholic
Aug 20, 2009 06:48 PM
killablaze
Nov 16, 2005 12:12 PM
infamousALLMTR
Sep 15, 2002 08:12 AM
hadookn
Nov 13, 2001 11:03 PM
JM Performance
Sep 16, 2001 03:50 PM
