Possible for obd0 engine to run without Resistor box?
Old Oct 11, 2005 | 02:58 PM
HatchBox's Avatar
Skoobie no more...
Default Possible for obd0 engine to run without Resistor box?
90 civic, b16, dual point > multipoint fuel injection swap.
It ran ok for a bit then progressivly got worse. Injectors ended up being out of spec on the ohm readings.
Decided to check all my wiring. So I back probed pins A13 and A15.
From ECU to Main relay it has continuity.
But From Resistor box to either ECU or Main relay has no continuity.
I must have a open in the line at some point. From the Resistor box to the splice point.
Here is a Wiring diagram.
Is it possible for the car to run for a short period of time normally?
Then would this fry my injectors? Because the voltage has no place to go?
Old Oct 11, 2005 | 03:04 PM
Chiovnidca's Avatar
Default Re: Possible for obd0 engine to run without Resistor box? (HatchBox)
Do you have battery voltage at the red wire on the injector resistors? What resistance do the injectors measure?
Old Oct 12, 2005 | 04:35 AM
JimBlake's Avatar
Default Re: Possible for obd0 engine to run without Resistor box? (Chiovnidca)
It couldn't have run like that, so while it was running that wire must have been intact.
Are you asking whether you should wire that power (main relay pin 7) directly to the hot side of the injectors? I'd say no, that would not be good. But I've never done it so ??
You've already identified where the open-circuit is. Why don't you fix it? I don't see any reason (in what you said) to believe the resistor box is screwed up.
Old Oct 12, 2005 | 01:24 PM
HatchBox's Avatar
Skoobie no more...
Default Re: Possible for obd0 engine to run without Resistor box? (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">It couldn't have run like that, so while it was running that wire must have been intact.
You've already identified where the open-circuit is. Why don't you fix it? I don't see any reason (in what you said) to believe the resistor box is screwed up.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">It couldn't have run like that, so while it was running that wire must have been intact.
yes i know. but im just trying to figure out how it ran without that wire...and why would it get worse and worse
ChiantiHatch
Jul 28, 2018 03:36 PM
siguy2k
Aug 21, 2012 09:46 PM
oldschoollove
Feb 11, 2010 07:06 PM
HatchBox
12
Jan 13, 2006 05:29 PM
ekblacknight
Jun 20, 2005 01:35 PM
