IDLE 3k after engine swap
Old Oct 11, 2005 | 02:05 PM
PaChiLa Leader's Avatar
Default IDLE 3k after engine swap
My car IDLEs at 3k... crazy high.. what should i do?
i tried to retarded the timing by moving the distrubtor forward & adjust the IDLE screw clockwise to the end.. only managed to get to 1100 RPM (still high) then code 14 (IACV defective circult or unplugged/defective sensor) came on...
what should i do now?
Old Oct 11, 2005 | 02:13 PM
Lord Helmet's Avatar
Default Re: IDLE 3k after engine swap (PaChiLa Leader)
check for vacuum leak around the IACV and vacuum lines and pin ***** leaks in the rubber lines. you put the engine in diagnostic mode before you played with the timing right?
Old Oct 11, 2005 | 03:22 PM
Default Re: IDLE 3k after engine swap (Lord Helmet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lord Helmet &raquo;</TD></TR><TR><TD CLASS="quote"> you put the engine in diagnostic mode before you played with the timing right? </TD></TR></TABLE>
..um... no.. i did it when the car is running~ did i do it wrong??
DirtyRussian
13
Mar 29, 2016 09:14 AM
November
Apr 21, 2007 01:57 PM
NoVALude
Nov 20, 2006 11:02 AM
Civic Hybrid
27
May 29, 2006 04:02 PM
jerbear!
May 9, 2005 11:00 AM
