What Car is this Cluster from?
Not quite sure what car this came from..revs to 8, tach goes to 95? Also, the check engine light doesn't have the word "check" on it, and the ebrake button has (( ! )) (( ))
instead of BRAKE. And it has a gas light, which lights up when I open the door lol.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VegasEFHB »</TD></TR><TR><TD CLASS="quote">I have no clue, but if you are willing to get rid of it, I will trade ya my 89 Si cluster with 190k on it
Thanks for the offer but no thanks..just bought it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr_Si-R »</TD></TR><TR><TD CLASS="quote">i think it can be a few differnt kinda of clusters. it could be a ukdm crx...maybe? what kinda of car is it in?</TD></TR></TABLE>
It's in a 91 civic std.
Aren't 88-89 and 90-91 clusters different? So it had to be from a 90 or 91 car but what motor revs to 8?
</TD></TR></TABLE>Thanks for the offer but no thanks..just bought it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXTAZC »</TD></TR><TR><TD CLASS="quote">Looks like a ZC cluster?</TD></TR></TABLE>
Definately not a zc cluster. I'm only saying that because zc's don't redline at 8 grand.
It's definately not from Japan. Canadian?
Not Canadian, ive only seen US clusters with the yellow dash for 55mph ( I could be wrong). IF you notice the dimmer switch, afaik no EDM cars used a dimmer switch as the rear foglight switch went in that spot ( I think)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K20EF8 »</TD></TR><TR><TD CLASS="quote"> IF you notice the dimmer switch, afaik no EDM cars used a dimmer switch as the rear foglight switch went in that spot ( I think)</TD></TR></TABLE>
That doesn't come with the cluster though, thats stock and it wasnt switched with the cluster.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmef1991 »</TD></TR><TR><TD CLASS="quote">it's an EDM cluster the JDM one reads in KM's the EDM and USDM read in MPH and KM's</TD></TR></TABLE>
On the EDM cluster the Kmph are dominant on the speedo side, and the MPH are smaller and on the inner ring.
It looks like someone bastardized a cluster and put a higher rpm (edm/jdm) tach in.
As for the dimmer, the rear foglight button on EDM models is lower and to the right, not directly left where that dimmer switch is.
If i can get a camera ill take a pic of my EDM cluster and surround for a comparison.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgator »</TD></TR><TR><TD CLASS="quote">You are all wrong...
it is a 90-91 USDM cluster with a EDM tach and painted needles...</TD></TR></TABLE>That kind of where I was leaning because there is no way that the speedometer would be in MPH.
the needles are painted yes i forgot to mention that..
but why are all the lights different. no us ef's even had gas lights.
The last time I checked the Speedometer could be swapped with no issue, but the tach and cluster were one unit. With that in mind, wouldn't that make it a USDM speedometer in an EDM cluster (EDM did have the gas lights and a funky brake light) or just some form of special EDM cluster in one shot? It looks an awful lot like a UK ZC with a well used USDM speedometer, but that is simply my best guess.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swifty4u »</TD></TR><TR><TD CLASS="quote">
but why are all the lights different. no us ef's even had gas lights. </TD></TR></TABLE>
**** you are right, i could barely see that on my shitty monitor...opps...im retarded
it is a EDM/UKDM VT cluster with a 90-91 USDM Speedo...
on me for being a retard...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VegasEFHB »</TD></TR><TR><TD CLASS="quote">The last time I checked the Speedometer could be swapped with no issue, but the tach and cluster were one unit. With that in mind, wouldn't that make it a USDM speedometer in an EDM cluster (EDM did have the gas lights and a funky brake light) or just some form of special EDM cluster in one shot? It looks an awful lot like a UK ZC with a well used USDM speedometer, but that is simply my best guess.</TD></TR></TABLE>
you can also swap out the VT tach into a 90-91 USDM cluster...
you can also swap out the VT tach into a 90-91 USDM cluster...</TD></TR></TABLE>
How would I do so? I would love that tach in my USDM 88-89 Si cluster.
How would I do so? I would love that tach in my USDM 88-89 Si cluster.</TD></TR></TABLE>
not sure if it will fit in yours...arent they different shaped?
