3 rpm
Old Oct 11, 2005 | 11:11 AM
gsrHB's Avatar
Default 3 rpm
iight i have a 96 civic hb and i swapped it with a jdm b16 and when it gets to 3 rpms it starts to die out or should i say lose power, whats wrong?
Old Oct 11, 2005 | 11:13 AM
Luserkid's Avatar
Default Re: 3 rpm (gsrHB)
Can you be anymore vague? Also cars cant run off 3 rpms. Do you know how slow that is? Try atleast to idle at 700 rpm then the car will stay alive.
Old Oct 11, 2005 | 11:15 AM
litterbox's Avatar
I am a (Trial User) Army
Default Re: 3 rpm (Luserkid)
LOl at the funniest title in a while.
Old Oct 11, 2005 | 11:19 AM
IHateJDM's Avatar
Default Re: 3 rpm (litterbox)
so it somehow makes power at 1 and 2 rpms?
probably timing.
Old Oct 11, 2005 | 11:21 AM
dewoine's Avatar
Default Re: 3 rpm (IHateJDM)
maybe he was saying 3000 rpms
Old Oct 11, 2005 | 11:23 AM
litterbox's Avatar
Default Re: 3 rpm (dewoine)
Well, yeah.
IHateJDM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dewoine &raquo;</TD></TR><TR><TD CLASS="quote">maybe he was saying 3000 rpms</TD></TR></TABLE>
no ****? anyways, the flaming is not due to his typo, its because he didn't tell us enough about the problem to be able to help.
Old Oct 11, 2005 | 11:27 AM
gsrHB's Avatar
ok yea the car idles fine but when i put it in first gear and hit around 3000rpms the car loses all its power and rocks back and forth same for everyother gear is that alittle more vague?
Old Oct 11, 2005 | 11:29 AM
Luserkid's Avatar
Not really but its better then what you started use with. When you go past 3000 does it do the same or does it go away?
ehh i gotta get ready for work, some of the others guys will help you
IHateJDM's Avatar
any cel's?
Old Oct 11, 2005 | 11:33 AM
gsrHB's Avatar
yea it stays the same untill i switch the gear then when i put it in the second gear and it hits around 3000rpm it does the same thing and it does the same **** for the rest of the gears, basically i cant get any power from my motor after 3000rpms
Old Oct 11, 2005 | 11:36 AM
IHateJDM's Avatar
cel = check engine light.
you should get a timing light and make sure its right.
Old Oct 11, 2005 | 11:40 AM
gsrHB's Avatar
no there is no engine light on, u mean a tach?
Old Oct 11, 2005 | 11:50 AM
IHateJDM's Avatar
check engine light comes on in the guage cluster (orange). If you don't have it, get a timing light and check your timing. Your belt probably skipped a tooth.
Old Oct 11, 2005 | 12:00 PM
gsrHB's Avatar
yea there is no orange cel on so u think i shoudl just replace the timing belt?
Old Oct 11, 2005 | 12:03 PM
IHateJDM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrHB &raquo;</TD></TR><TR><TD CLASS="quote">yea there is no orange cel on so u think i shoudl just replace the timing belt?
you don't need to replace the belt unless the belt is old, or looks worn. If it jumped a tooth, your motor will run like crap. A timing light will tell you if its off or not.
Old Oct 11, 2005 | 02:05 PM
flood's Avatar
I think you should take your car to a mechanic...and no, not your uncle.
Old Oct 11, 2005 | 02:12 PM
Farmer Brown's Avatar
No what you need to do is tell us what you did. Right ECU? Right wiring? Right parts? It wouldnt have hurt to have checked the timing on the engine before you put it in though. Hard to see where the cams are in relation to the cam with it all together. Might want to check and see if at least the cams are lined up with eachother.
Slick-Prelude487
Feb 22, 2008 10:26 AM
gray_civic_coupe
31
Nov 22, 2005 08:31 AM
beer4me20
Aug 2, 2005 05:08 PM
GSpeedR
Jul 21, 2003 07:33 PM
