MPFI??????
Old Mar 4, 2002 | 10:17 PM
hondacivic4g's Avatar
Default MPFI??????
Ok,will any D16 motor MPFI bolt up to a D15?I have a 91 hatch w/ 1.5L DPFI (STD)70 HP (Go-cart) engine.
I checked out a local Junk yard and found a couple 86 & one 88 integra's with motors. Looked up the Specs and they are both D16's (D16A & D16A3)
Would the MPFI from one of them, bolt up to my D15?
If so what ECU do I need to make it work?
Later-HC4G
Old Mar 4, 2002 | 10:26 PM
superslowhatch's Avatar
Default Re: MPFI?????? (hondacivic4g)
U mean D16a6 dohc ? No it will not. Y don't u just put the one from CRX Si same year as your ? ( 89-91 sohc ) Do you interest in Si motor ? ( come from my CRX )
This engine will bolt right up and I will let it go for cheap.
Old Mar 5, 2002 | 02:54 AM
wronghand's Avatar
Default Re: MPFI?????? (superslowhatch)
My understanding is that the MPFI form the 1st generation integra would have to be ported to line up correctly. Your best bet would be to find the MPFI from an 88-91 Si. To get the most from the MPFI swap you will also need the The Si cam and ecu as well.
Lewd Nate
10
Nov 25, 2007 01:26 PM
stock00civic
28
Aug 25, 2006 10:29 AM
1SickHb
20
Apr 23, 2004 04:05 AM
gsrhatch22
Mar 19, 2002 11:08 PM
