Our H23 w/JDM cams - Dynojet numbers
Old Oct 10, 2005 | 10:17 PM
Bserious's Avatar
Default Our H23 w/JDM cams - Dynojet numbers
Combo's
First (4/16/05):
JDM H22 longblock
- Locked VTEC/JDM cams
- Skunk2 Manifold w/70mm T.Body
- RC 310cc
- 4-1 race header
- Eliminated balancing shafts
- No cam gears/straight up
Resulted: 204.2/154.3
Second (10/10/05):
- Same as above
- Swapped crank and rods from an F22 (were curious to see results)
Results: 238/179.0
Scanning dynosheet tomorrow.
Amazing? No. Pontential? Yes.
310's were maxed at 60 PSI.
Question... What is the higher N/A horsepower you have seen from all internal OEM Honda parts, including Type R?
Added Dyno Plot: http://www.quartersportsdrag.com/H_Dynos/Zac.jpg
Modified by Bserious at 6:10 PM 9/9/2006
Modified by Bserious at 6:11 PM 9/9/2006
Old Oct 10, 2005 | 10:22 PM
Bserious's Avatar
Default Re: Our H23 w/JDM cams - Dynojet numbers (Bserious)
Just had to post, as this combination is a no brainer.
Old Oct 11, 2005 | 05:06 AM
PirateMcFred's Avatar
Sounds fun. Have you got a pics of the header or dyno? What pistons? Stock JDM? What did you use to tune?
Pirate
Old Oct 11, 2005 | 07:35 AM
skunked's Avatar
The best thing about this motor is how cheap it is to build.
Good **** Seth
Old Oct 11, 2005 | 07:37 AM
skunked's Avatar
Default Re: Our H23 w/JDM cams - Dynojet numbers (PirateMcFred)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PirateMcFred &raquo;</TD></TR><TR><TD CLASS="quote">Sounds fun. Have you got a pics of the header or dyno? What pistons? Stock JDM? What did you use to tune?
Pirate</TD></TR></TABLE>
DynoJet, I'm pretty sure he said stock JDM pistons and Hondata. With bigger injectors and cam gears there is a little more in her for sure.
PS-I told you those injectors are too small!!!!
Old Oct 11, 2005 | 08:45 AM
dkim48's Avatar
Default Re: Our H23 w/JDM cams - Dynojet numbers (skunked)
just curious why lock the vtec?
Old Oct 11, 2005 | 09:18 AM
rhd's Avatar
rhd
so this is with the h2b as well?
and what's up with the header? 1.875? 2"? what collector?
this build fasicnates me......and if you don't mind...more details would be GREATLY appreciated!
Old Oct 11, 2005 | 09:43 AM
skunked's Avatar
Default Re: (rhd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rhd &raquo;</TD></TR><TR><TD CLASS="quote">so this is with the h2b as well?
this build fasicnates me......and if you don't mind...more details would be GREATLY appreciated!</TD></TR></TABLE>
yep, Seth produced this H2B kit.
Old Oct 11, 2005 | 09:45 AM
rhd's Avatar
rhd
i know he made it...but is it in use with this engine was what i was asking...
i mean, i assume it is...but you know how that goes. just want to be sure
Old Oct 11, 2005 | 09:47 AM
skunked's Avatar
Default Re: (rhd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rhd &raquo;</TD></TR><TR><TD CLASS="quote">i know he made it...but is it in use with this engine was what i was asking...
i mean, i assume it is...but you know how that goes. just want to be sure</TD></TR></TABLE>
Oh yeah, it does for sure. His car was the first to have one of his kits and still runs it.
Old Oct 11, 2005 | 09:49 AM
JDogg's Avatar
im wondering what pistons you used... if you put f22 crank and rods in it, the piston will stick out of the hole ALOT and hit the head.....
Old Oct 11, 2005 | 09:59 AM
puregroove's Avatar
Default Re: Our H23 w/JDM cams - Dynojet numbers (JDogg)
Old Oct 11, 2005 | 10:20 AM
skunked's Avatar
Default Re: Our H23 w/JDM cams - Dynojet numbers (puregroove)
pic of the car. See the shifter rods
Old Oct 11, 2005 | 11:36 AM
Bserious's Avatar
Yes, JDM cams (locked VTEC for ease of tuning), H2B, F22 crank & rods, & JDM 22 pistons.
I love my 310cc's!
Battle is this weekend, we'll see what she can do.
Old Oct 11, 2005 | 01:42 PM
Forrest Gump 9's Avatar
By using the F22's crank and rods, you are increasing the displacement to about 2.3L right? I also thought that the F22's crank is the same as the H23's crank. Just some thoughts.
Old Oct 11, 2005 | 04:35 PM
Bserious's Avatar
Default Re: Our H23 w/JDM cams - Dynojet numbers (Turbo9Nut)
H23/F22 crank, same part number.
Old Oct 11, 2005 | 04:40 PM
Professor15's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bserious &raquo;</TD></TR><TR><TD CLASS="quote">H23/F22 crank, same part number. </TD></TR></TABLE>how about the Rods are they the same length? this set-up looks impressive, sounds to me like a poor-mans K-series lol.
Old Oct 11, 2005 | 04:44 PM
Bserious's Avatar
Default Re: Our H23 w/JDM cams - Dynojet numbers (drchulo)
Edit
Modified by Bserious at 9:58 PM 6/13/2006
Old Oct 11, 2005 | 04:46 PM
accord387's Avatar
rods are also the same, nice numbers
Old Oct 11, 2005 | 06:04 PM
Honda318dx's Avatar
Default Re: (accord387)
Damn, that much difference with a H23/F22 bottomend? Hum...
Old Oct 11, 2005 | 06:50 PM
eg:R's Avatar
you running a b series tranny?? with conversion kit??
Old Oct 11, 2005 | 07:38 PM
ricepicker's Avatar
Default Re: (eg:R)
That's awesome to know that an F22 and H23 Crank are the same. I just picked up an H23 that was siezed, now I don't have to worry about the crank being screwed up. I was gonna do an All motor build up on my H22.
Old Oct 11, 2005 | 09:20 PM
Bserious's Avatar
Default Re: (ricepicker)
Just to clarify, both setups were with the H2B, same tranny.
Old Oct 11, 2005 | 10:32 PM
mgags7's Avatar
nice test, and good results.....now lets see the f23 crank in there on the same dyno, and see what the extra 2mm is worth
good job
Old Oct 12, 2005 | 02:58 AM
tdo's Avatar
tdo
Default Re: (mgags7)
do you have the regular jdm pistons or the type s pistons?
thats some pretty nice numbers for a stock internal H series.
edit - off topic but what kind of mounts was used with the H2B plate?
