With higher comp motors, can you use colder plugs to prevent detonation
With higher comp motors, can you use colder plugs to prevent detonation ?
If you run a colder plug can you use lower octanes?
Colder plugs will help but ultimately, you need to be running higher octane fuel or retuning if your engine is detonating on pump gas.
DCtwoR
Aug 17, 2002 12:35 PM
