d15b2 y8 crx . 15.42 do you believe?
Old Oct 10, 2005 | 07:50 PM
fiero2m4's Avatar
Default d15b2 y8 crx . 15.42 do you believe?
Arite so i bought a 1991 crx si . no a/c d15b2 bottom end. d16y8 head. Turbo edit, launch control, resonated exhaust with borla muffler at the end. Ported and polished. rebuilt bottom end. metal head gasket . 5 speed si tranny. lowered 13" steelies. And some misc stuff in between. Tuned by KMA racing Its Casey Inmans old car if you guys know who he is. I was told it runs 15.42 which i believe because i was shown timeslips of it and had numerous people tell me they were there and witnessed it.
ive got a buddy of mine that is like no way that b/s not possible blah blah blah. its only 105 hp this and that
" so either that single cam makes 130WHP, which is AS MUCH as a B16, or, its a bunch of BS"
" even with 110whp it only runs a 15.8"
just to quote him saying it wont run 15.42
dont get me wrong my friends cool its just hes stuck to his side on this one. just gotta prove him wrong lol
well i was just seeing what you guys thought. Is this possible? i believe it do you?
Old Oct 10, 2005 | 07:53 PM
Sepheroth86's Avatar
Default Re: d15b2 y8 crx . 15.42 do you believe? (fiero2m4)
just had to add this into my watched topics
Old Oct 10, 2005 | 07:58 PM
paulzy's Avatar
I believe it, with the right driver and some weight reduction, it's very possible
Old Oct 10, 2005 | 08:07 PM
dunkd's Avatar
uhh its got vtakk y0, i believe it
Old Oct 10, 2005 | 08:14 PM
tealegg's Avatar
i watched it happen at lapeer drag way.
Old Oct 10, 2005 | 08:26 PM
thumbtack's Avatar
With a very damn good driver, this would be possible...
You would deffinetly need about 115-120whp to acheive this though. Has the head been milled? Block resurfaced? That all raises the compression. What about the port and polish job... is it a exospeed (send the head out job)? or just a mild in the shop type deal? What is the cylinder compression on the last compression check reading?
There is alot to be seen here yet. I find it very hard to believe a stock d15b2 and a "port and polish" y8 head managed this run with only that going for it.
Old Oct 10, 2005 | 08:28 PM
thumbtack's Avatar
Default Re: d15b2 y8 crx . 15.42 do you believe? (thumbtack)
also, you say the bottom end was rebuilt? What pistons are being used? D15B2 or maybe some other pistons?
Old Oct 10, 2005 | 08:35 PM
tealegg's Avatar
not my car but i helped put the motor togather/in the car. the bottem end is a stock rebuild. stock bore and all. the head was ported buy a buddy that at the time worked at a machine shop. heh we accualy never did a compression test on it. the head was resurfaces also. it uses a stock y8 head gasket. the 15.4 was the best out of prolly 12 runs all day long. the rear interior was out and the head light was also took out. casey is a pretty good driver also. so that helps alot oh yea.. and it was WB02 sensor tuned.
Old Oct 10, 2005 | 08:49 PM
thumbtack's Avatar
Default Re: d15b2 y8 crx . 15.42 do you believe? (JDustinM)
well your friend says it is a metal (I take that to mean either an aftermarket, or modified one piece stock).... why didn't he say stock headgasket... we know they are metal. Head was resurfaced how far? interior was out? What else was removed... As I said above... possible but too many details are left out. That engine NEEDS atleast 115 whp to accomplish that run. That is alot of power to get with out any power adders.
How about exhaust? was it open header? What was the track temp and air temp? Doesn't need to be exact... was it a hot day/cold day... night or day? I don't really care how good a driver you are, without the power you will not see those times. I have an "estimated" untuned 180whp and ran a 14.2 @103 mph. Did it multiple times. No traction and cold as **** weather/track.
Old Oct 10, 2005 | 08:59 PM
dunkd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thumbtack &raquo;</TD></TR><TR><TD CLASS="quote">well your friend says it is a metal (I take that to mean either an aftermarket, or modified one piece stock).... why didn't he say stock headgasket... we know they are metal. </TD></TR></TABLE>
some sohc headgaskets are not metal.
Old Oct 11, 2005 | 06:28 PM
tealegg's Avatar
Default Re: d15b2 y8 crx . 15.42 do you believe? (dunkd)
2.25 exhaust and a Mr. gasket oem style 3 ply head gasket. the head was resurfaced just enough to make the surface flat. i dont remember how many thousandths. it was prolly 75-80 degrees out that day.. honestly i was quite suprised how good that car ran. **** i only ran a 14.6 with my boosted DA teg.. but my 60 foot was 2.7 and the mph was 99. the track really has no prep at all.. so its pretty amazing to me how it pulled that time. **** the crx was running even up with a b16 ef hatch.
Old Oct 11, 2005 | 07:01 PM
What was the trap speed of the crx on that run?
Old Oct 11, 2005 | 09:39 PM
tealegg's Avatar
Default Re: d15b2 y8 crx . 15.42 do you believe? (Sepheroth86)
i dont remember high 80's mabe. some reason 89 mph sticks in the back of my mind.
Old Oct 11, 2005 | 11:12 PM
Mista Bone's Avatar
D Tranny Guru
a little slow if you ask me..........
My D15B7 (same bottom end) with NO VTEC, just a A6 cam went 15.08@ 88 mph.........
In 1999!!!!!!!!!!
Old Oct 12, 2005 | 01:51 AM
Outkast95LS's Avatar
Default Re: (Mista Bone)
1.998 60' Was that on street tires?!
Old Oct 12, 2005 | 01:57 AM
dr_latino999's Avatar
Default Re: (Outkast95LS)
It's Mista Bone, with his super knowledge of gearing he probably found someone to cheat the laws of physics and put his horrific power levels to the ground
Old Oct 12, 2005 | 07:32 AM
1point5CRX's Avatar
Default Re: (dr_latino999)
i believe it, i went 15.1@90 with a 2.2 60ft. sohc zc with bolt ons & stock 13" steelies
Old Oct 12, 2005 | 12:46 PM
Mista Bone's Avatar
D Tranny Guru
just 175/50/13 Yokohamas..........
Old Oct 12, 2005 | 03:02 PM
What Yokohama tires did you use? Impressive 60' none the less if it was on street tires. Especially on a set of 175/50/13's
Old Oct 12, 2005 | 09:57 PM
Mista Bone's Avatar
D Tranny Guru
175/50/13 A008 RSII made for Mini Coopers, 19.9" OD
Old Oct 13, 2005 | 07:33 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote">a little slow if you ask me..........
In 1999!!!!!!!!!!
Interesting.
My d15b7 with a d16z6 head, with the "ghetto vtec switch" ran high 15's low 16's at like 83mph.
Old Oct 13, 2005 | 09:46 PM
PSI2HI's Avatar
Former Vendor
Default Re: (Sepheroth86)
Buddies all stock D16Z6 92 CX went 14.99@93mph on the shitty 13 year old oiriginal tires 2.38 60'. For ***** put my 24.5's on and it wetn 14.601. Weights ~1940, stock motor, stock header, no exh, stock clutch...
Old Oct 13, 2005 | 09:59 PM
asefi944's Avatar
bmp
Old Oct 14, 2005 | 12:31 PM
Calvinator's Avatar
Default Re: (PSI2HI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PSI2HI &raquo;</TD></TR><TR><TD CLASS="quote">Buddies all stock D16Z6 92 CX went 14.99@93mph on the shitty 13 year old oiriginal tires 2.38 60'. For ***** put my 24.5's on and it wetn 14.601. Weights ~1940, stock motor, stock header, no exh, stock clutch...</TD></TR></TABLE>
damn thats impressive. Weight and traction play a huge factor.
Old Oct 14, 2005 | 03:37 PM
CoreyR's Avatar
Default Re: (xtremeazian)
how is 15.4 hard to beleive in whats probably a 2000lb CRX with a mini me? you people realize 15.4 is not fast right? if he said he pulled a mid 14 i would say its BS.
