stock gsr compression, should I keep my buddy club spec 3+ cams
Set Up:
b18c1
b16 trans
head milled 10 thousandths
buddy club spec 3 + cams
omni valve-train with ti retainers
skunk 2 intake mani
dc sports 4-2-1 2.25 collector
will be upgrading to jdm itr soon
2.5 custom exhaust
aem cai
chipped p28 with basically a lightly modified gsr map (I don't know much about ecus)
Im not looking to do a tare down so the block will remain stock, im just looking to get more power. I was wondering if any one had any recommendations on dif. cams or what, any comments would be appreciated.
Thanks
b18c1
b16 trans
skunk 2 intake mani
2.5 custom exhaust
aem cai
Thanks
If your block will remain stock, why change those cams? Even BC3+ require more cr then b18c1 provides. Yes they work OK with stock CR, but much better with higher one.
I see that your head is milled slightly, also Omni valve train, does that include flat valves?
Anyway, if you are getting JDM itr motor soon, what is the point?
I run bc3+ with b18c1 and 11.5:1 cr, and they work great. Can I get more power with different cams? Yes, but BC3+ delivers very nice powerband, and after 20K it is not eating away at the rocker arms either, so all in all reasonable compromise. Not to mention that with BC3+ you car run stock GSR intake valve spring setup, which again results is less abuse because of less seat pressure.
Anyway try not to over-cam your motor, you are better off with slightly smaller ones...
also according to password jdm "Spec III plus were designed to accommodate compression ratios from 10.0:1 to 13+.", thats why i got them but i was just wondering of anything else I could
slowpokecivic
Nov 10, 2006 03:07 PM
MJobe
20
Mar 30, 2006 07:16 PM
phantom_sol
Jul 7, 2004 10:00 AM
