oil in manual transaxle?
Old Oct 10, 2005 | 05:35 PM
eag36's Avatar
Default oil in manual transaxle?
Hey guys. I just replaced my clutch and when refilling my transaxle fluid i called up the honda dealership to ask if the honda transaxle fluid was just 90 weight gear oil and the guy said 'no no no... you don't want to use 90 weight... it'll make shifting really hard.' So he said to use regular 10-30 weight motor oil. But i'm still skeptical because i know what i drained was gear oil... no other oil smells like gear oil.
Opinions?
Old Oct 10, 2005 | 05:38 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: oil in manual transaxle? (eag36)
whaaaat you went to a dealer and they didn't try to sell you Honda MTF? That's quite surprising.
Use Honda MTF, or GM Synchromesh Friction Modified (if you want to spend ~$9/qt.). I run the latter, and I absolutely love it.
Old Oct 10, 2005 | 05:40 PM
Sam92Teg's Avatar
Default Re: oil in manual transaxle? (PatrickGSR94)
Ya, Honda MTF, takes about 2.4 quarts and is $3.75 a quart at my local Honda dlr.
Old Oct 10, 2005 | 05:47 PM
AlphaQup's Avatar
Default Re: oil in manual transaxle? (Sam92Teg)
hahaha It's funny how this topic always pop up. PENZOIL SYNCHROMESH... same **** as GM synchromesh & wont cost you as much.
Buy GM sychromesh if you are skeptical and have lots of money.
Old Oct 10, 2005 | 06:15 PM
eag36's Avatar
ok, but my question right now is, will i be fine with 10-30 motor oil in my gearbox?
Old Oct 10, 2005 | 06:28 PM
PURPLETERROR aka BIGMATT's Avatar
you will be fine with 10w30
Old Oct 10, 2005 | 06:48 PM
projectTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">whaaaat you went to a dealer and they didn't try to sell you Honda MTF? That's quite surprising.
Use Honda MTF, or GM Synchromesh Friction Modified (if you want to spend ~$9/qt.). I run the latter, and I absolutely love it. </TD></TR></TABLE>'
i called up my local acura dealership and he said unless they specify that they want honda mtf back in, they just put non synthetic 10w30 in. you should be fine with the oil. i just switched to honda mtf after about 1.5 years of driving on oil and it made a huge diffence in the shifter feel....its smoother now. BTW you transmission on a fill up normally takes 2-2.3 qts depending on how much was drained.
Old Oct 10, 2005 | 07:23 PM
Community Builder
Default Re: oil in manual transaxle? (AlphaQup)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AlphaQup &raquo;</TD></TR><TR><TD CLASS="quote">hahaha It's funny how this topic always pop up. PENZOIL SYNCHROMESH... same **** as GM synchromesh & wont cost you as much.
It is NOT the same as GM Synchromesh Friction Modified, which is what I've been using for over 60K miles now.
I'm willing to bet there aren't too many people if any who have run this fluid in a Honda as long as I have.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eag36 &raquo;</TD></TR><TR><TD CLASS="quote">ok, but my question right now is, will i be fine with 10-30 motor oil in my gearbox?</TD></TR></TABLE>
It will be okay as long as you don't use synthetic motor oil. Okay, as in, there is other stuff that would be better (MTF, Synchromesh, etc.).
Old Oct 10, 2005 | 08:41 PM
AlphaQup's Avatar
We've argued about this in the past and there is no use argueing again. Think what you wanna think. Spend more money, I don't care.
Do a search on this subject!! It's been covered.
Old Oct 11, 2005 | 03:34 PM
eag36's Avatar
cool, thanks for the info
Old Oct 11, 2005 | 03:52 PM
tcteg's Avatar
my freind is replacing his clutch and was told to use 10-30???
Old Oct 11, 2005 | 03:59 PM
Community Builder
Default Re: (tcteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tcteg &raquo;</TD></TR><TR><TD CLASS="quote">my freind is replacing his clutch and was told to use 10-30???</TD></TR></TABLE>
It will work (conventional, NOT synthetic), but other things are better, as mentioned above.
Old Oct 11, 2005 | 06:08 PM
apok's Avatar
Default Re: (PatrickGSR94)
Use Honda unless you have a hard time shifting, then switch to Syncromesh.
Redline is another brand, but I haven't heard much about it myself.
Old Oct 12, 2005 | 10:13 AM
2G0S0R1's Avatar
New User
Default Re: (apok)
Dumped my synccromesh FM (had for 19k) and went back to OEM... feels the SAME, but I dont get a "slipping/squeeking" sound anymore if i launch hard.
Yay to OEM fluid, but whatever... I have used everything now and even regular 10w30 seemed fine.
Old Oct 12, 2005 | 12:00 PM
MrAngry's Avatar
... don't put motor oil in your tranny.
the synchros are cheap enough as it is.
don't encourage their breakdown.
Old Oct 12, 2005 | 12:50 PM
gsrious's Avatar
Default Re: (MrAngry)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrAngry &raquo;</TD></TR><TR><TD CLASS="quote">... don't put motor oil in your tranny.
don't encourage their breakdown.</TD></TR></TABLE>it really wont do any harm using 10w30. people do more harm to the tranny, than the tranny does to itself.
thiscivicuser
17
Mar 3, 2008 08:45 PM
Gsir8
Jan 22, 2007 07:13 PM
SOHCMAN
Nov 4, 2004 08:06 AM
petrv
May 30, 2003 01:56 PM
Quick 200k Mile Motor
Jan 11, 2002 10:59 AM
