what is going on here
Old Oct 10, 2005 | 03:51 PM
accrd18's Avatar
Default what is going on here
can anyone help me out here. everytime i turn my rear defroster on and have the radio on all i get it static. turn defoster off. radio becomes clear as crystal. its not the radio station or nething i tried changing that already. everything else works fine like my front defroster,heater,a/c n that stuff.
Old Oct 10, 2005 | 04:10 PM
notoriousB's Avatar
Default Re: what is going on here (drivinaway367)
assuming you're talking about the 98 accord in your sig, the radio antenna is part of the rear window - the top "mesh" area that's impossible to tint right is the antenna. sounds like your defroster circuit is somehow interfering w/ the antenna. any cuts/shorts in the defroster lines on the window?
Old Oct 10, 2005 | 04:14 PM
accrd18's Avatar
Default Re: what is going on here (notoriousB)
i didnt check that. i hope not. but then ur saying i turn on the antenna when i turn on the defroster?
Old Oct 10, 2005 | 04:18 PM
89Lxi-boy's Avatar
how many horses are gained from a cai 89 accord
Old Oct 10, 2005 | 04:19 PM
accrd18's Avatar
Default Re: (89Lxi-boy)
wtf does that have to do with this topic do a search or post a new topic.
Old Oct 10, 2005 | 04:22 PM
hondabum's Avatar
no what he is saying is that it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by notoriousB &raquo;</TD></TR><TR><TD CLASS="quote"> sounds like your defroster circuit is somehow interfering w/ the antenna. any cuts/shorts in the defroster lines on the window?</TD></TR></TABLE>
look for a loose wire that has worn thin from heat or somthing, next to your defroster lines in the door
Old Oct 10, 2005 | 04:28 PM
HondaTechPro's Avatar
Default Re: what is going on here (hondabum4life)
This concern is not new to the Accords. Alot of times, when a tint job is done, the installer cuts or damages one of the defroster grid wires. The cut wire causes the static. There are aftermarket defroster grid "repair" pastes... but I have never had any luck using them, so unfortunately, replacing the rear glass is usually the only fix.
Old Oct 10, 2005 | 04:31 PM
BLKFLSH's Avatar
You don't turn on an antenna. It does'nt have power going to it. When you turn on the defroster it interferes with the reception because maybe the wires are touching in the winshield.
Old Oct 10, 2005 | 04:43 PM
accrd18's Avatar
Default Re: what is going on here (BLKFLSH)
i thought it was cool i didnt have a obviuos antenna outside the car...now im starting to wish i had one there instead of on my rear window. i think the tint thing is what caused the problem. although what weird about it is that the tinting took place a long time ago and it just started this yesterday. ill c if i can find the small cut in any of the defroster wires. if not o well i guess ill have to live with it cuz there aint no way im replacin my window for that. as long as my defroster doesnt quit on me.
tjjm36m3
Mar 10, 2009 08:34 AM
tjjm36m3
Mar 3, 2009 01:43 PM
tonyjrp19
May 12, 2006 06:00 PM
ILOVEGIRLS
Apr 28, 2003 09:32 PM
phateless
Jan 22, 2003 09:02 AM
