flywheel question
im goin from a b16 tranny to a gsr tranny....i no the gsr os longer but i like it better....if i get a lighten flywheel will it make up for the long gears? ive heard with a lighter flywheel it will rev up quicker but in top end it sucks is that true?
i have an lsvtec swap....sum people say b16 is the best(obviously the type r one is best) one for an lsvtec...after alot of runs my tranny starts gettin rough.....should i just save and buy an itr tranny or get this b16 one fixed?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hialeahzbg »</TD></TR><TR><TD CLASS="quote">with a lighter flywheel it will rev up quicker</TD></TR></TABLE>
Yes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hialeahzbg »</TD></TR><TR><TD CLASS="quote">but in top end it sucks</TD></TR></TABLE>
No.
Yes.
No.
so u recommend me puttin a lighter flywheel in a gsr tranny? i like the si tranny cuz everytime i shift im on vtec....but i like the gsr tranny cuz its better for highway....so if i put a lighter flywheel in the gsr tranny will it make up for being a bit longer than the si tranny?
They're all pretty much the same, just different weights. The lighter you get, the faster the engine will change revs, both up and down. I have a Clutchmasters on my B18, which is 12 lbs, and fits my style perfectly. I find when I shift, the revs drop right to where they will be in the next gear, making the car very smooth to drive. My friend has a Fidanza on his B16, which is 7 lbs. I find it personally to be too light, as the revs drop too fast and you get a little lurch when you shift, but it's partly due to me being used to the heavier one. I still think you have to shift a bit too fast to drive the 7 lb flywheel smoothly, but it's all personal preference.
Do <U>NOT</U> lighten the stock flywheel.
It will never be equal, it doesn't really work that way. There's no magic formula to make it accelerate the same. Just get a lighter one, trust me, it will be better.
i was reading here on a thread and they were talkin about changing there staters....if i put a fidanza flywheel will i need 2 get a different starter other than the starter on the gsr.....should i keep the b16 starter and put it in the gsr? does it make a difference....help me b4 i get rid of it with the starter......
