best performance adders with $7000
Old Oct 10, 2005 | 11:07 AM
Nyris's Avatar
Default best performance adders with $7000
What would be the best things to do with $7000 to a crx, and be able to hit all aspects, like suspension and tranny, and engine, and have close to 300 horse.
Old Oct 10, 2005 | 11:10 AM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: best performance adders with $7000 (Nyris)
search
Old Oct 10, 2005 | 11:14 AM
TH33G4MON3's Avatar
Default Re: best performance adders with $7000 (Ace$nyper)
buy a b20 swap with GSR tranny build the internals ie. pistons rods valve springs etc. buy turbo kit slap it on tune the **** out of it... then dyno
Old Oct 10, 2005 | 11:24 AM
1's Avatar
Default Re: best performance adders with $7000 (TH33G4MON3)
Sell your car for $1000 and give me all the cash. 225 h.p. is enough for my 88 HF
Old Oct 10, 2005 | 11:47 AM
CRX Toad's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ace$nyper &raquo;</TD></TR><TR><TD CLASS="quote">search
Ace you are so wise
First I would determine what in the heck you want to do with the car.
Is this going to be a street car, auto-x, road race, drag race, or show car. You can do a lot with $7000 and a CRX. Figure out where you want to go and plot your map to that point.
Old Oct 10, 2005 | 12:12 PM
88 rex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TH33G4MON3 &raquo;</TD></TR><TR><TD CLASS="quote">buy a b20 swap with GSR tranny build the internals ie. pistons rods valve springs etc. buy turbo kit slap it on tune the **** out of it... then dyno </TD></TR></TABLE>
That'll never happpen for $7k
Old Oct 10, 2005 | 12:21 PM
eumoria's Avatar
7k is a pretty penny to spend on a CRX. But it all depends on what you want to do... because if you want to make an all out autox car all of a sudden 7000 doesn't seem like much
however if all you want to do is go in a straight line, 7k can get you there real fast. A B Series turbo may be a good option. The K Series swaps are tantilizing but you'll spend 5 out of the 7 just getting the K in there so in the end you may be able to go faster with a boosted B.
Old Oct 10, 2005 | 10:08 PM
Nyris's Avatar
Default Re: best performance adders with $7000 (eumoria)
P.S. this original post was my friend useing my acct. he wants a crx.
i want a 88-89 civic hatch
Old Oct 11, 2005 | 06:48 AM
BlueShadow's Avatar
I dont know why people keep suggesting the B20 as a candidate for boost. Everybody says that the cylinder walls are too thin and will eventually crack even if you do have it tuned right. Better to just swap an LS in and turbo that, or a built B16 with nitrous.
Old Oct 11, 2005 | 10:07 AM
vw eater's Avatar
Default Re: best performance adders with $7000 (BlueShadow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueShadow &raquo;</TD></TR><TR><TD CLASS="quote">
I dont know why people keep suggesting the B20 as a candidate for boost. Everybody says that the cylinder walls are too thin and will eventually crack even if you do have it tuned right. Better to just swap an LS in and turbo that, or a built B16 with nitrous.</TD></TR></TABLE>
iam going b20vtec seems like a good choice and ive herd both ways on the turbo b20
Old Oct 11, 2005 | 06:35 PM
BlueShadow's Avatar
Default Re: best performance adders with $7000 (vw eater)
B20VTEC N/A is fine, but B20 or B20VTEC turbo is too risky. There is more then enough proof out there that the B20 stock sleeves are too weak. The extra displacemtn helps out a lot when you are going NA. But with a turbo you can easily gain that same amount of power by running an LS but with slightly higher boost.
hermistonkilla
Classic Hondas
Nov 3, 2008 08:59 AM
CroSi
10
Jan 19, 2008 06:12 PM
emwavey
Jan 13, 2006 05:26 AM
STP_crx123
Oct 25, 2005 09:27 PM
98AccordEX
May 9, 2003 08:29 PM
