B16A swap from EG to EK, motor has already been made OBD0 > OBD1. ?'s
My B16 EG coupe was killed. One of the 2 replacement cars will be a EK coupe with a Y8, the other a EF hatch Si.
Of course it is my CIVIC DUTY to put my B16A into the EK. And Y8 into the hatch, after I make a kill video of the D16A6.
The B16A was converted to OBD1 from OBD0 for the EJ1. So, what wiring will I use to make the EK OBD1? Do I splice the OBD2 EJ8 harness into the original engine harness, and buy the ECU connector adaptor? Or should I just transplant the whole harness as is off the EJ1 and into the EJ8?
Also, this swap will bolt right over with a 99-00 Si rear mount, right? I can use my EJ1>B16 axles, and shiftlinkage in EJ8>B16?
Now with the Y8 into the ED7, which OBD is recomeneded? OBD2 using the EJ8's original engine harness, and P2P, or keeping OBD0 and adding the VTEC wire, and a PW0 or PR3 ECU?
If the B16 was in an EJ, why did you make it OBD0?
You will need new motor mounts to fit that motor in the EK. To make it OBD1 I am unsure of the specifics as I have never done it, however you will probably need OBD1 injectors, engine harness and distributor, along with a jumper harness on the ECU.
Edit: nm, i saw that you made it OBD1 from 0.
oresama
Oct 15, 2009 09:21 AM
