cant get tranny apart
Old Oct 10, 2005 | 06:10 AM
Lmgrcivic's Avatar
Default cant get tranny apart
I have all the bolts off the tranny housing and it came apart about a inch and I cant get it to come apart any farther.
Old Oct 10, 2005 | 06:23 AM
98 Spec R's Avatar
Default Re: cant get tranny apart (Lmgrcivic)
There is a C Clip you have to release at the same time you pull the case off. Get a Helms manual.
Old Oct 10, 2005 | 07:25 AM
Lmgrcivic's Avatar
Default Re: cant get tranny apart (98 Spec R)
thanks
Old Oct 10, 2005 | 07:37 AM
Sam92Teg's Avatar
And the trickier part will be getting that C-clip back on when you go to put the cases back together. I used the C-clip pliers with one hand and slowly tightened the case bolts untill it brought the bearing up and the C-clip went around the bearing. Then I tighted all the case bolts, turned the tranny over, and lifted and bounced the tranny on some 2X4's untill I heard a pop. This causes the shaft and bearing to seat in the grove correctly. Kinda hard to describe and explain in words but maybe you can get a general idea. Worked like a charm tho. Good luck.
Oh, I just reread your post. Are you just removing the tranny or seperating the tranny case to get to the gears and shafts. If you are just removing your tranny from the block, maybe you missed one of the lower bolts on the back side. You don't have to remove the C-clip to pull the tranny from the block.
Old Oct 10, 2005 | 07:43 AM
98 Spec R's Avatar
Default Re: cant get tranny apart (Sam92Teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sam92Teg &raquo;</TD></TR><TR><TD CLASS="quote">And the trickier part will be getting that C-clip back on when you go to put the cases back together. </TD></TR></TABLE>
Yes, getting the case back on can be tricky sometimes.
Sic_DA_Nine
Mar 29, 2007 02:51 PM
Boostedb20EH2
25
Mar 26, 2007 06:46 AM
prelude1897
Mar 31, 2005 12:20 PM
wreckedmyteg
Jul 18, 2004 06:30 AM
stRtypR25
Dec 20, 2002 01:35 PM
