no spark
Old Oct 10, 2005 | 04:16 AM
acmeotally's Avatar
Default no spark
i started up my car and it stall i tried to start it back up and it would just turn over. so i waited till the morning and it still just turned over.
i know its not my main relay becuase i just changed it. i put a screwdriver in the sparkplug wire and put it close to metal to test if there was spark and there was none. my guess is it was the ignition module becuase that's what i found when i searched
but im not sure if it is or where to locate it.
sry for the long story, and thanks for any help
Old Oct 10, 2005 | 04:19 AM
acmeotally's Avatar
Default Re: no spark (acmeotally)
i meant ignition control module
Old Oct 10, 2005 | 05:30 AM
acmeotally's Avatar
anyone?
its a 92 stock si
Old Oct 10, 2005 | 06:46 AM
egryda's Avatar
ICM is on the distributor. youll only see it when you remove the distributor cap. when you get to it, look for burn marks where it shorted out inside. most likely your problem. its easy to get to.
Old Oct 10, 2005 | 09:32 AM
acmeotally's Avatar
Default Re: no spark (egryda)
is there a spring that goes from that to the cap? because i found the spring inside the cap not attached. the piece the spring is supposed to go into is black on the end.
i thinks its the problem thanks for your help
ecerva5792
Jul 22, 2010 06:20 AM
shaylude
Jun 17, 2010 08:19 AM
ianae86
12
Apr 12, 2006 06:05 PM
vangc6780
Aug 10, 2005 08:40 AM
Takumi Fujiwara
Jun 15, 2004 06:49 AM
