tranny?
Old Oct 9, 2005 | 10:55 PM
whiteef-8's Avatar
Default tranny?
i have a b16 civic hatch and everytime i drive it, every gear i put it in has so much play in it, meaning when i put it in first or any gear it still feels like nuetral,
what does this mean? I'm thinkin bushings? or may be a tranny problem?
Old Oct 9, 2005 | 11:03 PM
Redline130's Avatar
Default Re: tranny? (whiteef-8)
Could be the bushings. What kind of shift linkage are you using?
Old Oct 9, 2005 | 11:04 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: tranny? (Redline130)
i would bet its a shift linkage bushing or your shift linkage.
Old Oct 9, 2005 | 11:21 PM
whiteef-8's Avatar
Default Re: tranny? (sanimalp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline130 &raquo;</TD></TR><TR><TD CLASS="quote">Could be the bushings. What kind of shift linkage are you using?</TD></TR></TABLE>
what should i be lookin for? old busted bushings? how do i know its the shift linkage?
Old Oct 9, 2005 | 11:27 PM
FlatlineEF9's Avatar
I got the same problem. I think its the bushings because i just changed the linkage. Im gonna go with the energy suspension urethanes. I have heard great things.
Old Oct 9, 2005 | 11:50 PM
Redline130's Avatar
If the bushings are old, cracked, or just worn out, then your shifter will feel real sloppy. If the shift linkage is the culprit, you may have a hard time getting it to go into gear or the shift pattern will be off.
Old Oct 10, 2005 | 03:22 PM
sanimalp's Avatar
$cat /dev/urandom
yeah if you got some do-it-yourself shiftlinkage, there might be welds that would run around the circumference of the linkage, but near the shifter i believe. the end links are obviously welded on, but what you should look for are welds that are in the middle of the shaft of the linkage itself.
Old Oct 11, 2005 | 12:10 AM
whiteef-8's Avatar
thanks for all your help
o yea, and go rota!
Old Oct 11, 2005 | 08:44 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whiteef-8 &raquo;</TD></TR><TR><TD CLASS="quote">go rota!</TD></TR></TABLE>
Lokisdope
Apr 1, 2008 11:29 AM
JDM_EK4_Coupe
May 25, 2007 08:14 PM
UrVtecIsLoud
Jul 26, 2006 07:26 PM
CivicRaping
Mar 25, 2005 05:47 AM
Justin127
Dec 30, 2002 10:28 PM
