sketchy way to drop a motor...wouldnt recommend it again.
Old Oct 9, 2005 | 09:21 PM
the.hamburglar's Avatar
Default sketchy way to drop a motor...wouldnt recommend it again.
next time ill rent a hoist. it was hard to keep the motor balanced on a 2x4.
Old Oct 9, 2005 | 09:35 PM
Default Re: sketchy way to drop a motor...wouldnt recommend it again. (ronmexico)
who the hell are you? obviously you have alot of time drawing *****. hmmm, would i rather draw ***** or post 3 times on HT. newbies
Old Oct 9, 2005 | 09:42 PM
( o )( o )'s Avatar
Default Re: sketchy way to drop a motor...wouldnt recommend it again. (the.hamburglar)
just buy a hoist. you can find them for like 160 which is the cost of a few rentals. i have used mine many times, a must-have for someone who does their own engine work like this.
Old Oct 9, 2005 | 09:44 PM
Default Re: sketchy way to drop a motor...wouldnt recommend it again. (( o )( o ))
yeah i know. thats why i dont recommend it again
Old Oct 9, 2005 | 09:53 PM
smkngsr's Avatar
the hoist will cut down the work time to as much as half but u can definitely put the motor up without a hoist. my buddy and i did it but we didnt put the motor all together. we did the same way u did except the trans. so we put the short block and then the trans. its much easier
Old Oct 10, 2005 | 01:11 AM
Blind-Fashion's Avatar
i do it from under neath like that, i just use a motor cycle jack because it holds the motor evenly, and its 10x's easier going through the bottome (like they were meant to be done)
Old Oct 10, 2005 | 04:38 AM
Chillinit's Avatar
Default Re: (Blind Fashion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blind Fashion &raquo;</TD></TR><TR><TD CLASS="quote">i do it from under neath like that, i just use a motor cycle jack because it holds the motor evenly, and its 10x's easier going through the bottome (like they were meant to be done)</TD></TR></TABLE>
I did the exact same thing. Those motorbike jacks come in handy.
Old Oct 11, 2005 | 07:08 AM
drdisco69's Avatar
You guys are making it too difficult. You unbolt everything, lay the engine on some tires and lift the car off the engine. So simple!
Old Oct 11, 2005 | 07:25 AM
Ekay Jay's Avatar
Default Re: (drdisco69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 &raquo;</TD></TR><TR><TD CLASS="quote">You guys are making it too difficult. You unbolt everything, lay the engine on some tires and lift the car off the engine. So simple! </TD></TR></TABLE>
Or u could just unbolt everything and pull the motor out of the car
Old Oct 11, 2005 | 08:08 AM
LSVTEC 91 Civic's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ronmexico &raquo;</TD></TR><TR><TD CLASS="quote">here is a sketch of how i do my swaps.
http://artpad.art.com/?io4otj1669n0 </TD></TR></TABLE>
Brilliant
Old Oct 11, 2005 | 08:22 AM
skunked's Avatar
Default Re: sketchy way to drop a motor...wouldnt recommend it again. (LSVT3K 91 C1V1C)
it's actually prettt easy and safe to drop the motor/tranny out from the bottom. I use a 4 wheel dolly and place it under the motor then lower the car over the dolly until the motor is sitting on the dolly. Bust your mounts loose then raise the car up, roll the motor out on the dolly.
Old Oct 11, 2005 | 08:26 AM
Ekay Jay's Avatar
Default Re: sketchy way to drop a motor...wouldnt recommend it again. (skunked)
I work in a bodyshop, when we need to pull the engine we put it on the lift and drop the whole engine,susp,ect. Takes us about 3 hours.
Old Oct 11, 2005 | 09:31 AM
stevel's Avatar
yeah, i don't know why you guys need jacks or motorcycle stuff. Too complicated. We just lower the car to the ground, unbolt it all and then jack the car up and slide the motor out. You can have it out in about an hour and half.
s
Old Oct 11, 2005 | 09:40 AM
skunked's Avatar
Default Re: (stevel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stevel &raquo;</TD></TR><TR><TD CLASS="quote">
s</TD></TR></TABLE>
I do the same but I use a 4wheel dolly under the motor to roll it out.
Old Oct 11, 2005 | 10:11 AM
stevel's Avatar
Default Re: (skunked)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked &raquo;</TD></TR><TR><TD CLASS="quote">I do the same but I use a 4wheel dolly under the motor to roll it out.</TD></TR></TABLE>
yeah, that's even better and still simple. The 4 wheel dolly is really good for when you put the motor back in, you can move it around easy.
s
Old Oct 11, 2005 | 10:27 AM
skunked's Avatar
s</TD></TR></TABLE>
Exactly.
Old Oct 11, 2005 | 11:05 AM
flyrod's Avatar
Looks like it worked! Don't try that with a domestic V8 for sure!
Old Oct 11, 2005 | 01:49 PM
Kendall's Avatar
I usually use a forklift and lift a pallet up to the bottom of the engine, unbolt it, and drive away with it.
Old Oct 11, 2005 | 02:26 PM
joelsgirlisfatandugly's Avatar
Default Re: (Kendall)
we just jack the car up from the front and drop the motor out! Thats if you know what your doing!
Old Oct 12, 2005 | 07:00 AM
HeikDiesel's Avatar
Default Re: (joelsgirlisfatandugly)
I go from the bottom with a creeper. Makes putting it in much easier than with a cherry picker from the top beacuse you have to angle it in due to the transmission
Old Oct 12, 2005 | 08:30 AM
EK9-Stealth's Avatar
i just snap my fingers and its done... SAaaa...Zaamm..
JJsMotorsports
Oct 12, 2011 09:24 AM
M@
Oct 9, 2005 11:32 AM
97B18C5civic
Sep 29, 2005 10:42 PM
BlendedEJ8
14
Jun 25, 2003 10:02 AM
Weslay
Dec 3, 2001 12:12 PM
