headlights won't work (sometimes)
Old Oct 9, 2005 | 08:37 PM
wrXtian's Avatar
Default headlights won't work (sometimes)
ok so last night i was at work and i got into my car and started it.. everything started just fine, but i went to turn on my headlights and they didn't turn on at all. the headlights didn't come on, tail lights, guage cluster lights, interior lighting, and license plate frame lights didn't come on and the clock didn't dim.. i turned the car off and pulled the cover underneath the steering wheel where the fuses are.. i looked at it and didn't mess with anything.. i just waited a second and then switched on my lights and they came on and everything was fine..
later that night i was at my friends and i was getting ready to leave. i started the car and tried to turn on the lights and they didn't come on again.. same situation with none of the lights coming on at all. i tried flipping the little switch on and off and nothing happened. finally i stuck my hand down and pushed all the fuses in a little tighter and started my car.. i flipped the switch and the lights came on. i drove home and when i got into my driveway i turned the car off and i turned the lights off. i turned them back on and they came on again.. i turned them off and on a few times and they worked all the time..
finally.. tonight i get into my car leaving a friends place and the lights wouldn't come on again! i flipped the switch on and off a lot of times and no luck. i pushed the fuses in and everything and tried turning the lights on but no luck. i sat pushing the fueses turning the switch for the lights on and off a bunch of times and no luck.. i turned the car off turned it on jiggled the fuses more and still the lights would not come on. finally over time maybe 15 mins the lights finally came on.. i don't know what tricked them to come on. when i got back here i messed with the lights again.. i turned them on and off a few times and they still worked. i am completely stumped. it seems if it was a fuse only one part of the lights wouldn't work, but the cluster would still light up and the tail lights and what not.
does anyone have any ideas?? this problem seems to keep getting worse and worse.. any help at all would be great! thanks
Old Oct 9, 2005 | 09:22 PM
1QuikSOHCZC's Avatar
Default Re: headlights won't work (D16A6_HF)
im thinking maybe u have a loose connection sumwhere...but im not sure where? check ur relays and make sure ur connections dont get wet and stuff.. mine got wet and it was a huge hassle......check ur ground wires....if i can think of sumthin else ill be back
Old Oct 9, 2005 | 10:15 PM
EFwithS2000taillights's Avatar
The contacts in your column are known to go bad. that would involve replacing your column instruments. Another problem that is common is the ground box for the system.
Old Oct 14, 2005 | 01:11 PM
wrXtian's Avatar
Default Re: (EFwithS2000taillights)
it's strange the headlights have been working recently.. i'm just wondering when they might go out again i think it may be something in my column.. how do i replace these things and what do i need to repleace?
Old Oct 14, 2005 | 10:34 PM
wrXtian's Avatar
Default Re: (D16A6_HF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D16A6_HF &raquo;</TD></TR><TR><TD CLASS="quote">it's strange the headlights have been working recently.. i'm just wondering when they might go out again i think it may be something in my column.. how do i replace these things and what do i need to repleace?</TD></TR></TABLE>
Old Oct 18, 2005 | 02:50 PM
wrXtian's Avatar
now the headlights will turn on and off sometimes by themselves after i get them to work.. before if i got them to work they would work, but now they'll have a mind of their own.
i noticed in the fuse area all the wrong fuses were in there.. they were mostly 30 and i know 10's are supposed to be in there.. i changed the fuses back to what they're supposed to be, but i don't know if this could have damaged something??
Old Oct 18, 2005 | 08:33 PM
wrXtian's Avatar
anyone have the slightest clue?
Old Oct 20, 2005 | 09:35 AM
wrXtian's Avatar
at all?
Old Oct 21, 2005 | 05:52 AM
EvolDead's Avatar
youll have to chase the wires down and see where they lose voltage.Having bigger fuses can smoke your wires if theres a problem.
Old Oct 21, 2005 | 02:34 PM
wrXtian's Avatar
Default Re: (EvolDead)
i changed the fueses and now they seem to work better.. sometimes they will turn off and then turn back on again.. but they do work a little better now.. knock on wood
Old Oct 21, 2005 | 02:59 PM
cvcrcer's Avatar
If you have an aftermarket radio I would check the dimmer wire that went to the factory radio. It's black with a red stripe.
If not that I would check the headlight switch.
Old Oct 21, 2005 | 03:19 PM
db8xc1x39
Guest
Posts: n/a
switch iin the column, check all wiring from the switch all the way down to the fuses, pull fuse and check as well. maybe corroded and the contact isnt good.
Old Oct 22, 2005 | 10:05 AM
wrXtian's Avatar
Default Re: (db8xc1x39)
i know the fuses are good.. i took off the cover to the ignition and the switch and the plug into it looks alright.. the wires from there don't look like there should be any problem..
Old Oct 28, 2005 | 12:00 AM
Donkey85's Avatar
the problem is bad headlight switch...... change it and the problem will be gone i had ths ihappen on my 89
Jrustboy
Sep 26, 2013 04:44 AM
areed404
Jun 15, 2012 08:25 AM
EgNickCx
17
Mar 9, 2012 08:14 PM
pliskin8
Jul 7, 2011 06:30 PM
hankd
Nov 24, 2004 11:08 AM
