Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Wheel hop then CEL on b16
Old Oct 9, 2005 | 05:27 PM
coot_er's Avatar
Default Wheel hop then CEL on b16
i was autocrossing my b16 rex today and had a problem. when i was on a staight away i was getting alot of wheel hop and then all of my dashlights went on, oil, CEL etc. i look at the ecu for the code and it was a solid red light. when i shut the engine off and turned it back on it was fine, no cel, and perfect idle. i ran three runs fine and then it happened again in the same place. what could it be? i did just replace my clutch, t-belt, and water pump but i don't think that would have anything to do with it. oh, i also drove it home which is 1.5 hours away and it was fine.
Old Oct 10, 2005 | 06:59 AM
coot_er's Avatar
Default Re: Wheel hop then CEL on b16 (coot_er)
any help?
Old Oct 10, 2005 | 07:25 AM
ralphie14's Avatar
how violent was the wheel hop? Maybe the vibration is hard enough to mess up your ECU for a moment untill you turn the car off then on to let it kinda reset. Sounds wierd to me.
Old Oct 10, 2005 | 08:32 AM
coot_er's Avatar
Default Re: Wheel hop then CEL on b16 (ralphie14)
i would say the wheel hop was pretty violent. i have stock suspension which probably makes it worse. its just weird because i have done around 7 autoX this year and it has never happened.
Old Oct 10, 2005 | 09:28 AM
nfn15037's Avatar
Probably a loose sensor wire or ground on the ECU.
Old Oct 10, 2005 | 03:05 PM
coot_er's Avatar
Default Re: Wheel hop then CEL on b16 (nfn15037)
^^any ideas what sensor or what ground on the ecu??
Old Oct 11, 2005 | 01:09 AM
smokin rubber's Avatar
you said you just replaced your clutch, how many miles ago? did you break it in? get the flywheel resurfaced?
Old Oct 11, 2005 | 04:43 PM
coot_er's Avatar
Default Re: (smokin rubber)
flywheel was resurfaced, clutch has around 250 miles on it.
Old Oct 12, 2005 | 07:49 AM
nfn15037's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coot_er &raquo;</TD></TR><TR><TD CLASS="quote">^^any ideas what sensor or what ground on the ecu??</TD></TR></TABLE>
Something important like MAP sensor or the ground on the thermostat perhaps?
Old Oct 12, 2005 | 07:51 AM
89civicdx's Avatar
Check the ground on the thermostat housing.
edit: nfn15037 already said it
BAD9AZZ1MOFO5
Aug 30, 2012 10:38 AM
midorihatchkid
Oct 27, 2009 07:14 PM
VTEC-LUDE
Aug 24, 2009 01:25 PM
coot_er
25
Oct 12, 2005 07:53 AM
91~CRXSi
Apr 26, 2002 01:16 PM
