just a couple internals!
EDIT: What Do You All Think Of This Setup?
D16a6 block
Z6 Vtec head
88-89 D16A1 (p29) pistons
ZEX street/strip camshaft
Walbro 255lph fuel pump
-what head gasket should i go with and any other suggestions? this will be a daily driven motor and later will be boosted on a custom turbo setup.
EDIT #2: should i go with an EX tranny? will it fit the D16a6 block?
Modified by Squallie at 8:08 PM 10/9/2005
Modified by Squallie at 8:15 PM 10/9/2005
D16a6 block
Z6 Vtec head
i believe they do fit, here is a link for some good oem upgrades for d series
http://www.d-series.org/forums...21761
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Squallie »</TD></TR><TR><TD CLASS="quote">ok thanks man, what head gasket should i use for these two?</TD></TR></TABLE>
well that all depends on how high u want ur compression, someone who has a compression calculator could prolly better answer that, i'm not exactly sure, r u having ur head milled at all?
