Timing marks on Buddy Club cams
Im trying to figure out where the marks are so I could check timing (I think the belt skipped a tooth.) Does anyone know where theyre at or how I could check the Cam timing to make sure its good???
OK thats cool and all but I have Buddy Club cam gears with no timing marks on them at all. Im trying to find out if there is another way of checking cam timing without using the gears.
just take a straight edge and it should still go through the center of the 4 bolts horizontally across the cams (somewhat level with your head). if you dont know which way up is look at your crank pulley.
SlammedDC2
Sep 8, 2012 08:01 AM
Jap_Spec_Imports
Dec 20, 2007 06:15 PM
