For new suspension, am I missing anything??
I have a 93 Integra LS, with all original suspension with over 183,000 miles and its time to replace the suspension. My questions is if maybe anyone knows of anything I might be missing that should be swiched out while replacing shocks and springs, or possibly better parts to use instead of what I have....so far it costing about $900.00 after installation. Thanks for the help!!
here is my list of what I will be buying so far...
1. - Tokico ILLUMINA 5 ways adjustable struts/shocks set.
2. - H&R Sport Springs.
3. - Adjustable front and rear Camber correction kit.
4. - Strut bar / tie bar 4 pieces combo kit.
5. - Energy Suspension rear trailing arm bushings.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BudgetLSRacer »</TD></TR><TR><TD CLASS="quote">your probably going to want to factor in seized bushings and such, youll probably need new control arms atleast</TD></TR></TABLE>
In just the rear??
seen this kit for the front, I might get it, cuase i think my front suspensions a mess..
Modified by DJHyperXK2004 at 6:28 PM 10/10/2005
In just the rear??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DJHyperXK2004 »</TD></TR><TR><TD CLASS="quote">
In just the rear??
Modified by DJHyperXK2004 at 6:28 PM 10/10/2005</TD></TR></TABLE>
were did you see that kit from? how much?
In just the rear??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DJHyperXK2004 »</TD></TR><TR><TD CLASS="quote">I have a 93 Integra LS, with all original suspension with over 183,000 miles and its time to replace the suspension. My questions is if maybe anyone knows of anything I might be missing that should be swiched out while replacing shocks and springs, or possibly better parts to use instead of what I have....so far it costing about $900.00 after installation. Thanks for the help!!
5. - Energy Suspension rear trailing arm bushings.</TD></TR></TABLE>
You might want to search around some, but I hear bad things about those bushings. Something about them not allowing the arm to move through the entire range it needs to move through.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG »</TD></TR><TR><TD CLASS="quote">
were did you see that kit from? how much?</TD></TR></TABLE>
Was a kit I saw on E-bay, looks like everything i need?? cost about 130 I think, they were on sale, lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by archmage »</TD></TR><TR><TD CLASS="quote">Most people recommend stiffer Mugen bushings instead... yea do a search on that</TD></TR></TABLE>
Yea now i do remember a while back, reading the long tread on that, they said better to use the mugen ones, or just go with another set of stock bushings, I only plan on keeping the car about 4 - 5 more years..
3. Not needed
4. Bling parts mostly; cut them out if you don't have the budget
5. Too stiff for that location, will cause suspension bind and bump steer - not pretty and quite dangerous. Use an OEM (they have seperate part numbers now) or Mugen (same as new OEM design, but much more expensive).
I would say take the money you'd waste on the tie bars and camber kit, and invest in the GC / Koni Yellow combo with OTS springrates and a good alignment. They can be had for less than $800 shipped; check out red shift motorsports, ususally have the best prices and Chris is a good guy to talk to.
3. Not needed
Is Mugen's TA bushings really the same as the OEM one? I remember someone had posted a site that did a review on it a while back, and iirc it came back inconclusive?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PIC Performance »</TD></TR><TR><TD CLASS="quote">Is Mugen's TA bushings really the same as the OEM one? I remember someone had posted a site that did a review on it a while back, and iirc it came back inconclusive? </TD></TR></TABLE>
the are made from the same mold, not material i believe.
the are made from the same mold, not material i believe.</TD></TR></TABLE>
The original OEM ones were not very strong, so Mugen made a very expensive replacement. Honda put out a TSB about TA bushing failures, and redesigned the bushing. It is now available seperately and nearly identical to the Mugen.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AutoXer »</TD></TR><TR><TD CLASS="quote">
what does this mean?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BbOi0420 »</TD></TR><TR><TD CLASS="quote">
what does this mean?</TD></TR></TABLE>
OTS - Off The Shelf spring rates. Pretty much for an integra ~350front/280rear
dem0nk1d
Jul 17, 2008 01:02 PM
