Need help im throwing code 21 and 22 in my 92 eg
Old Oct 9, 2005 | 01:20 PM
seanc520's Avatar
Default Need help im throwing code 21 and 22 in my 92 eg
I have a 92 civic cx with a b16a sir2 swap..every since ive got the motor swaped into the car ive been throwing code 21 and 22 which are VTEC spool solenoid valve and VTEC pressure valve..my question is how do i fix these codes? Id like to drive my car for once without a CEL. I dont think the codes are affecting me much performance wise b/c i ran a 14.0 at 101 in the 1/4 with I/H/E. But who know with these problems solved i might have ran a 13. Some let me know thanks!
Modified by seanc520 at 8:37 PM 10/9/2005
Old Oct 9, 2005 | 02:51 PM
brockscivic's Avatar
Default Re: Need help im throwing code 21 and 22 in my 92 eg (seanc520)
maybe your vtec isnt wired up right but it everything is in good order, take a paperclip and put it in ECU pins A4 and D6 and this will bypass the vtec codes...well it did for my JDM D15b vtec swap. Make sure if you choose to try this..wrap the middle of the paper clip with electrical tape so you dont short anything out.
Old Oct 9, 2005 | 04:16 PM
hatchi's Avatar
which wire harness are you using. your car is prewired for vtec but will need to be ran to shock tower plugs
Old Oct 9, 2005 | 07:34 PM
seanc520's Avatar
im using a b16 harness from a del sol.
preludeblue
Dec 18, 2005 02:35 PM
milton
Sep 25, 2005 07:25 AM
dreweg
Aug 2, 2003 08:55 AM
dreweg
Aug 2, 2003 08:53 AM
chet
Jul 17, 2003 11:57 PM
