headgasket????
Old Oct 9, 2005 | 11:41 AM
SomeDude56's Avatar
Default headgasket????
ok so started the old crx up and started burning mass oil and did the smoke screen and even had beads of oil in tailpipe. went out got a compession tester and here what i did 1. took all spark plugs and plug wires out of hole 2. pluged tester into each hole from 1-4 and every time i started id hold gas pedal down at WOT and let it off when i got out to check it, i only cranked the car 4-5 times as the instructions said to crank the car for the number of cylinder it had. numbers were 165, 160, 157, 173 was i not cranking long enough????
wtf could this be\
thank you
Old Oct 9, 2005 | 12:39 PM
SomeDude56's Avatar
Default Re: headgasket???? (SomeDude56)
bump b.c i need help
AudioFunk
Apr 16, 2014 09:24 PM
Ef4doorwagon
11
Jan 14, 2014 07:24 AM
1CaMw0nDeR
Jul 1, 2008 07:31 PM
SPOOLINmatt
Mar 3, 2006 10:01 AM
crazyimport
Feb 6, 2005 10:20 PM
