pr3 pistons in a stock gsr... tuning needed??
Old Oct 9, 2005 | 11:16 AM
mekanism's Avatar
Default pr3 pistons in a stock gsr... tuning needed??
I was just wondering if it is necessary to upgrade the fuel system and ecu to run pr3 pistons in a basically stock gsr. The block has an overbore of .02 and according to a compression calculator it puts it around 11.5:1. Should I go all out with a FPR,injectors,hondata etc.. or can I get away with running it stock for now?
Old Oct 10, 2005 | 04:36 PM
mekanism's Avatar
Default Re: pr3 pistons in a stock gsr... tuning needed?? (mekanism)
no one??
Old Oct 11, 2005 | 04:27 PM
mekanism's Avatar
anyone??????
Old Oct 11, 2005 | 04:38 PM
Rocket's Avatar
You'll be coo running stock maps with 2 degrees timing pulled out via the distributor if you run 91 octane.
Assuming the motor is healthy and does not consume oil.
Old Oct 11, 2005 | 04:42 PM
mekanism's Avatar
Default Re: pr3 pistons in a stock gsr... tuning needed?? (Rocket)
So the stock ecu will add enough fuel to compensate! I just want to make sure I dont destroy a new motor.
Old Oct 11, 2005 | 04:44 PM
boosted k20's Avatar
i think u'll be fine running those pistons w/o any timing pulled. i tuned a GSR with about 11.8 CR, timing was advanced from stock like 1.5* and the car was runing good. power and tq did not fall off with the timing advanced
Old Oct 11, 2005 | 04:51 PM
mekanism's Avatar
Default Re: pr3 pistons in a stock gsr... tuning needed?? (boosted k20)
Ok cool thanks. When I upgrade the top end I plan on getting all of goodies anyway but for now I dont have the cash. Also, do you guys think this engine will pass smog?
bmwe362006
73
Nov 14, 2009 06:35 PM
SkRoMeEnIzANoNo
Dec 1, 2008 04:42 AM
.adam.
Nov 30, 2005 10:57 AM
mugenhatchie
Mar 27, 2005 08:35 PM
*Boostwerks*
Jul 20, 2004 02:55 PM
