HIGH REVVING
can high revving burn out ecus or at least mess one up.Or maybe a distributer.Im still having this eratic idle and im trying to find ouy why.I idle the motor up by the cable to 1.5rps and it still drops way down and picks backup and drops again.any help would be appreciated.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by planetstereo »</TD></TR><TR><TD CLASS="quote">can high revving burn out ecus or at least mess one up.Or maybe a distributer.Im still having this eratic idle and im trying to find ouy why.I idle the motor up by the cable to 1.5rps and it still drops way down and picks backup and drops again.any help would be appreciated.</TD></TR></TABLE>
Are you talking revving about above the stock limiter or what?
I ASK BECAUSE THIS PROBLEM ALL STARTED WHEN I WENT FROM 3RD TO SECOND INSTEAD OF 4TH,THE CAR PROBABLY REVVED WAY HIGHER THAN IT SHOULD BECAUSE I BENT VALVES AND SPUN BEARINGS BUT I GOT THAT ALL FIXED.THE PROBLEM SEEMS TO BE ELECTRICAL BECAUSE IT IS SPORADIC.SOMETIMES IT RUNS GOOD OTHER TIMES THE IDLE FLUCTIATES TO ALMOST STALLING THEN PICKS BACKUP AND REPEATS.ANYONE HAD THIS PROBLEM WITH THERE ECU.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR Forum Guidelines »</TD></TR><TR><TD CLASS="quote">- No bumping. Makes a mess out of things. If the topic isn't active enough to stay on the first page, it probably wasn't that interesting anyways.</TD></TR></TABLE>
please read before posting <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by planetstereo »</TD></TR><TR><TD CLASS="quote">I ASK BECAUSE THIS PROBLEM ALL STARTED WHEN I WENT FROM 3RD TO SECOND INSTEAD OF 4TH,THE CAR PROBABLY REVVED WAY HIGHER THAN IT SHOULD BECAUSE I BENT VALVES AND SPUN BEARINGS BUT I GOT THAT ALL FIXED.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by planetstereo »</TD></TR><TR><TD CLASS="quote">I ASK BECAUSE THIS PROBLEM ALL STARTED WHEN I WENT FROM 3RD TO SECOND INSTEAD OF 4TH,THE CAR PROBABLY REVVED WAY HIGHER THAN IT SHOULD BECAUSE I BENT VALVES AND SPUN BEARINGS BUT I GOT THAT ALL FIXED.THE PROBLEM SEEMS TO BE ELECTRICAL BECAUSE IT IS SPORADIC.SOMETIMES IT RUNS GOOD OTHER TIMES THE IDLE FLUCTIATES TO ALMOST STALLING THEN PICKS BACKUP AND REPEATS.ANYONE HAD THIS PROBLEM WITH THERE ECU.</TD></TR></TABLE>
And after reading that I would say take it back to the place that worked on the car and tell them it isn't fixed still.
I AM A DO-IT-YOURSELFER THATS PROBABLY THE PROBLEM.HOW LIKELY DO YOU THINK AN ACURA DEALERSHIP WILL BE ABLE TO DIAGNOSIS MY PROBLEM.AT THIS POINT THIS MAYBE MY ONLY RESORT!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr1244 »</TD></TR><TR><TD CLASS="quote">ok. if you think it's ecu why dont you get a new one?
i could do that ,but if that aint it then il end up spending more money.its not really too bad of a problem but i would like to get it fixed
Vacuum leak? Highly unlikely. Check the:
coil
distributor and dissy internals
possibly replace the main relay that is located by the fuse box in the cabin.
Since these are all cheap items, test and or replace those first then if that doesn't solve it, take it back to the mechanic.
coil
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Haleiwa-Brando »</TD></TR><TR><TD CLASS="quote">Since these are all cheap items, test and or replace those first then if that doesn't solve it, take it back to the mechanic.</TD></TR></TABLE>
Ignition coils and ignitors arent really cheap.
The helms has diagnostic procedure for all of those items - get out your voltmeter and start tracking it down
i have this same problem with my 99jdm itr
sometimes idle will drop down and bog after i hit the clutch in after driving, sometimes idle will randomly get iractic or really low then spice up
it dosnt happen every day, typically it seems to happen more after running the car for a while or in the heat
sounds like the same problem.i thought maybe it could be dizzy.does any one know about distributor king on ebay. you can get a brand new distributor for like 160-180
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by planetstereo »</TD></TR><TR><TD CLASS="quote">could the dizzy go out sporadically like that?</TD></TR></TABLE>
Yes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by planetstereo »</TD></TR><TR><TD CLASS="quote">so i would know for sure!!!!</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ »</TD></TR><TR><TD CLASS="quote">The helms has diagnostic procedure for all of those items - get out your voltmeter and start tracking it down </TD></TR></TABLE>
Yes
