b16 hatch 1/8mile
Old Oct 8, 2005 | 09:11 PM
jsw_1986's Avatar
Default b16 hatch 1/8mile
I went out to the track tonight to watch the races, got there and decided to go ahead and run it. My car is a 95 civic hatch with a b16a2. only modification is a 2.25 cat back exhaust, and a short shifter, not to mention I'm running a p28 ecu. Lmk what you guys think and if any of you are pulling some of the same times and what your setup is
BEST TIME OF THE NIGHT------
reaction....7793
60'...........2.5056
330'.........6.6914
1/8 et......10.1811 @ 71.83mph
Old Oct 8, 2005 | 09:18 PM
T4eg's Avatar
Default Re: b16 hatch 1/8mile (jsw_1986)
work on the 60' they need alot of work...once that get knocked down the times will begin to drop. My friends stock B16a in 92 cx went 9.1 in 1.8th on bfgs
Old Oct 8, 2005 | 09:23 PM
92eg6's Avatar
Default Re: b16 hatch 1/8mile (T4eg)
car- 97 ek hatch full interior weighing 2455 (wats the point of a hatch might as well be a coupe)
r/t- .299
60'- 2.364
330'- 6.616
1/8- 10.018
ehh, my car weighs alot more then urs...but u deff gotta work on dat 60'
Old Oct 8, 2005 | 09:26 PM
jsw_1986's Avatar
Default Re: b16 hatch 1/8mile (92eg6)
yeah, I was running on some 16" enkei's with proxes for rubber. drag radials are due in the future, along with that p72 ecu. I've got a zex kit that still needs to be installed then should hit some definate good times.
Old Oct 8, 2005 | 10:54 PM
Capt. Jimbo McSubipants's Avatar
98 EK hatch with B16a2...just an intake and catback and type R ecu...type R mani and Type R TB, (crappy cluch...LS header...)
back seats were removed...
R/T.....622
60'......2.329
330......6.359
1/8......9.697
mph....73.49
1/4......15.032
mph......91.13
best time although i was consistent 15.3's...
your times are ok...i would get the dual cam ECU and a header...be 14's easy...i'm hopin for 14's with a header since i'm runnin an LS header.. and a new clutch since the OEM one is gone...
Old Oct 8, 2005 | 11:08 PM
sleeperbeauty's Avatar
my hatch- 1.5 sohc vtec at 2240 lbs, and 17 inch wheels.
RT.....252
60' 2.374
330' 6.561
1/8 10.053
mph 70.07
1000' 13.078
1/4 15.633
mph 86.19
i think you b16 guys are overrating yourselves.
Old Oct 9, 2005 | 12:14 AM
d16singlecammer's Avatar
Default Re: (sleeperbeauty)
Read my signature, and I was getting terrible traction. This was in 90 something degree weather, I'm pretty confident I could get it to run 9.9. I let my car cooled down and was going to make my last run of the day but blew my transmission when I launched. I will post new times in a month or so. Yeah work on your times, I believe B16 hatches are running 9.6 or so at the track I ran my car at. Good Luck
Old Oct 9, 2005 | 07:17 AM
jsw_1986's Avatar
Default Re: (d15singlecammer)
it's not we're over rating our selves it's you who is over crediting yourself. 15.6 on a stock motor being single cam is almost unrealistic. what mods to have pulled those times.
Old Oct 9, 2005 | 08:03 AM
ed like whoa's Avatar
work on ur 60ft
Old Oct 9, 2005 | 08:48 AM
Default Re: (jsw_1986)
Ha, 15.6 with a STOCK single cam is VERY realistic. It's just that you suck at driving, I pull consistent 2.2 in my 60's. In fact I ran a 10.2 with an 88 CRX DX completely stock with MPFI with full interior and AC. Learn how to drive and come back to us with a 9.6 eight mile time. Good Luck
Old Oct 9, 2005 | 08:55 AM
86crxls's Avatar
in another of his post's i believe he said he had a CX with 1.5 sohc vtec so i would assume it's a mini-me. now since we know that when you use the CX block to build a mini-me you have to change the pistons so i would assume that is done also. just a few assumptions that would make this all fit together.
just out of curiosity, what kinda times should be expected from a mini-me CX?
Old Oct 9, 2005 | 09:03 AM
Default Re: (86crxls)
Are you talking about me? I have a ZC Vtec 1.6 completely stock. If your talking about sleeperbeauty then I don't know.
Old Oct 9, 2005 | 09:05 AM
i thought my times were okay considering i'm dealing with having the most heaviest car of all of you....i'm lookin for 14's in the 1/4 next time..Thanks
Old Oct 9, 2005 | 09:15 AM
Default Re: (b16delteg)
B16delteg your times are fine, its just the jsw that is having some difficult time. He will do better after a couple of more runs
Old Oct 9, 2005 | 10:17 AM
jsw_1986's Avatar
remember I'm running the wrong ecu. the redline is at 7200 instead of 8000. so i'll be right in the middle of my power band and then have to shift. i'm sure once i have the right ecu i'll be doing 9.7-9.9, i plan on getting some drag radials to improve those 60' times. that ecu is playing a huge factor with my times. what are some good 60' times for a b16 anyways?
Old Oct 9, 2005 | 10:24 AM
jsw_1986's Avatar
also. i started looking through my slips there was one better time then that.
reaction----- .8085
60'-----------2.4974
330'----------6.6472
1/8 et--------10.1285 @72.1mph
Old Oct 9, 2005 | 12:38 PM
not to bash you or anything....but i don't even understand why your running your car on a single cam ECU....let alone racing it....
car should be a whole new world when you get a dual cam ecu...
Old Oct 9, 2005 | 02:29 PM
Luserkid's Avatar
60ft tells how good the driver is. Doesnt matter what motor is in there. From the looks of it you probably launched high as hell and just spinned through first.
With a lower 60ft you could get lower times. You could have drag radials and still run a shitty time. Tires doesnt always give for good times if you cant drive to begin with.
Old Oct 9, 2005 | 02:40 PM
JDM-97CX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d15singlecammer &raquo;</TD></TR><TR><TD CLASS="quote">Ha, 15.6 with a STOCK single cam is VERY realistic. It's just that you suck at driving, I pull consistent 2.2 in my 60's. In fact I ran a 10.2 with an 88 CRX DX completely stock with MPFI with full interior and AC. Learn how to drive and come back to us with a 9.6 eight mile time. Good Luck</TD></TR></TABLE>
OMG every body bow down before the god of driving in a straight ******* line. Why don't you climb down from your high horse, it isn't that hard to drag race.
Old Oct 9, 2005 | 07:55 PM
jsw_1986's Avatar
Default Re: (JDM-97CX)
hahahha.
anyways, no but nice try. i'm not an idiot i can drive, i was only launching at about 2200-2300rpm very little wheel spin through first little chirp threw second and continued to pull right till the end. I wasn't originally planning on racing it just happend i got there it was $5 more to race and figured what the hell i'll do it. i havn't got the right ecu because I havn't found one yet.
Old Oct 9, 2005 | 08:21 PM
I am by no means the GOD of driving, I'm just giving the guy advice and examples of the times he should be running. I am confident that once he is running the right ECU and gets some more seat time he will get consistent good times. Anyway good luck next time and make sure to post your times
Old Oct 10, 2005 | 08:02 AM
Markb16a's Avatar
now with my crx i had a few months back bofore I got my 92 hatch si I ran 9.4 all motor on a stock b16a obd-0 sir motor 1st out at jax raceways that was awesome to. but you guys should get 9.5 in your hatches. i see guys run 9.5 all the time on stock b16a in hatchs. but I just got scammed so i dont have a motor anymore oh well lata
Old Oct 10, 2005 | 08:33 AM
JDM-97CX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d15singlecammer &raquo;</TD></TR><TR><TD CLASS="quote">I am by no means the GOD of driving, I'm just giving the guy advice and examples of the times he should be running. I am confident that once he is running the right ECU and gets some more seat time he will get consistent good times. Anyway good luck next time and make sure to post your times </TD></TR></TABLE>
Telling some one that they suck at driving is not advice. You are a expletive, leave.
Old Oct 15, 2005 | 03:39 PM
jsw_1986's Avatar
my buddy was running 9.9 1/8 mile and a 15.0 1/4mile spinning through 3 gears. that was stock other than header, intake and a gutted cat. does anyone have any slips of b16's on nitrous?
ek_slut
Sep 16, 2005 06:05 PM
Redsun
Apr 27, 2004 09:30 AM
RyanAutry
Sep 24, 2003 05:29 PM
Hondasaurs
Jul 4, 2003 11:42 AM
