ACT OF GOD!!!!!!!
Old Oct 8, 2005 | 06:57 PM
213374U's Avatar
0x5359-0055
Community Builder
Default ACT OF GOD!!!!!!!
<FONT SIZE="3">NEW PROBS: Update Page 2</FONT>
OK, here's the story. Installed blue top 450's on my boosted Accord today. Of course after something like that, a street-tune is required. So my buddy (LSVT3C 91 CIVIC) came by the house and we hooked up his LM-1 wideband. We took it around made numerous pulls until we had it reading 12.5 AFR accross the board. She was running BEAUTIFUL!!!!! Gave her a few hard pulls and everything was wonderful.
UNTIL.... we pull up to a light waiting to turn and notice a lot of smoke coming from the engine bay. So I pulled into the next gas station, killed the car, and popped the hood. OIL EVERYWHERE!!!! I went through checking a couple of the obvious things... oil pressure guage feed line, turbo feed line, pressure sending unit, etc. Nothing... couldn't find where it was coming from. Manny then noticed that the top left bolt holding the valve cover on was missing. After a little looking we found the bolt..... THE THREADS WERE BROKE OFF IN THE HEAD!!!! What in the hell would cause this bolt to snap???
We were close to the Home Depot so we walked over to see what we could rig up just to drive it home without loosing anymore oil. We got it fixed and when I fired it back up I noticed there was a lot of blow-by coming from the breather filter. I'm thinking,"great... better call the bank." Start checking what we can and find out that the #1 cylinders plug "hole" has about 1.5" of oil sitting in it.
<U>Best case scenario:</U> The oil around the plug is causing the blow-by and only the bolt needs to be replaced.
<U>Worst case scenario:</U> Engine is done
Modified by Vt4cPwn35 at 11:16 AM 10/10/2005
Old Oct 8, 2005 | 07:04 PM
P_Adams's Avatar
Default Re: ACT OF GOD!!!!!!! (Vt4cPwn35)
And an obviously angry GOD he was!!
A bolt breaking at your time/milage interval can only be caused by several considerations; corrosion or multiple over tightening.
I think we can dismiss the corrosion theory since it's pretty much in an oil bath; so that leaves us with the overtightening senario.
Probably over the course of time the covers been off several times and installed without a torque wrench. Do that several times, and throw in a 'tweek' once in a while for the 'old oil leak, and "plink" the bolt stretches to its' limit and breaks.
P
Old Oct 8, 2005 | 07:17 PM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: ACT OF GOD!!!!!!! (P_Adams)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P_Adams &raquo;</TD></TR><TR><TD CLASS="quote">And an obviously angry GOD he was!!</TD></TR></TABLE>
Old Oct 8, 2005 | 07:25 PM
jb.'s Avatar
jb.
that blows so much
Old Oct 8, 2005 | 07:37 PM
LOGICx420x's Avatar
That sucks man.
Old Oct 8, 2005 | 07:40 PM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: ACT OF GOD!!!!!!! (LOGICx420x)
She was pulling so hard too.... couldn't wait to pwn someone
Old Oct 8, 2005 | 07:47 PM
fw190bvi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vt4cPwn35 &raquo;</TD></TR><TR><TD CLASS="quote">She was pulling so hard too.... couldn't wait to pwn someone </TD></TR></TABLE>
psh, your a newb and cant pwn ****....good luck man, hopefully there are no holes anywhere they're arent supposed to be, and things of that nature
Old Oct 8, 2005 | 07:53 PM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: ACT OF GOD!!!!!!! (fw190bvi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fw190bvi &raquo;</TD></TR><TR><TD CLASS="quote">psh, your a newb and cant pwn ****....</TD></TR></TABLE>
***** j00 mang
Old Oct 8, 2005 | 08:10 PM
HondaMike17's Avatar
its a good think you didnt try to pwn someone, because that probably would have made you feel 10x worse about everything when you were pulling the car at its hardest when it messed up
Old Oct 8, 2005 | 09:07 PM
matix's Avatar
Default Re: ACT OF GOD!!!!!!! (HondaMike17)
Go buy a new stud and bolt from honda and get a new sparkplug grommet gasket. This will fix the oil on the sparkplug.
Old Oct 8, 2005 | 09:24 PM
goowakjai
Guest
Posts: n/a
Default Re: ACT OF GOD!!!!!!! (matix)
whats our engine AFR suppose to be stock? i kno honda engine runs a little lean but 12.5 seems pretty lean to me..cud the increase in combustion chamber temp due to lean mixture have any cause in this?
Old Oct 8, 2005 | 09:43 PM
brads94accord's Avatar
Default Re: ACT OF GOD!!!!!!! (goowakjai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by goowakjai &raquo;</TD></TR><TR><TD CLASS="quote">whats our engine AFR suppose to be stock? i kno honda engine runs a little lean but 12.5 seems pretty lean to me..cud the increase in combustion chamber temp due to lean mixture have any cause in this?</TD></TR></TABLE>
lol 12.5 is lean? i think you've got it backwards bro thats pretty rich for a honda, but about perfect for a turbo honda. lean would be like a 15-17:1 AFR
Old Oct 8, 2005 | 10:01 PM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: ACT OF GOD!!!!!!! (brads94accord)
Well, bad news.... 170 150 70 80 . Those are the results of the compression test Guess it's time for a new motor
Old Oct 8, 2005 | 10:16 PM
P_Adams's Avatar
Not yet ......... Those readings would seem to indicate a blown cylinder head gasket between the two last cylinders. Yanking the head may be well worth it.
Did you do a wet compression test? If no improvement in readings, refer above. If they do improve, suspect rings / piston lands
P
eddited for content "Gasket"
Modified by P_Adams at 3:10 PM 10/9/2005
Old Oct 8, 2005 | 10:47 PM
213374U's Avatar
0x5359-0055
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P_Adams &raquo;</TD></TR><TR><TD CLASS="quote">Not yet ......... Those readings would seem to indicate a blown cylinder head between the two last cylinders. Yanking the head may be well worth it.
P</TD></TR></TABLE>
Head gasket???
But would that cause the blow-by???
Old Oct 9, 2005 | 01:33 AM
goowakjai
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brads94accord &raquo;</TD></TR><TR><TD CLASS="quote">
lol 12.5 is lean? i think you've got it backwards bro thats pretty rich for a honda, but about perfect for a turbo honda. lean would be like a 15-17:1 AFR</TD></TR></TABLE>
haha, my bad..thought backwards for a minute there...
Old Oct 9, 2005 | 05:32 AM
notoriousB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P_Adams &raquo;</TD></TR><TR><TD CLASS="quote">Did you do a wet compression test? If no improvement in readings, refer above. If they do improve, suspect rings / piston lands
P</TD></TR></TABLE>
^^ agreed. but the results are not promising. you usually don't get blow by with a blown head gasket.
12.5:1 is too lean IMO under boost, you guys should have been shooting for 11.5:1 or so. what system are you tuning with?
Old Oct 9, 2005 | 06:11 AM
P_Adams's Avatar
Default Re: ACT OF GOD!!!!!!! (notoriousB)
No, that's why I also included "Ring Lands / Rinds" as also a possibility.
P
Old Oct 9, 2005 | 06:20 AM
Jxi8s2k's Avatar
everytime i read one of your comments...your always saying stupid ****.
Old Oct 9, 2005 | 06:47 AM
Boosted Chemist's Avatar
Default Re: ACT OF GOD!!!!!!! (Jxi8s2k)
what where u tuning it with? what did your timing look like?
Old Oct 9, 2005 | 07:30 AM
fw190bvi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jxi8s2k &raquo;</TD></TR><TR><TD CLASS="quote">everytime i read one of your comments...your always saying stupid ****. </TD></TR></TABLE>
everytime i read something you say, i realize i dont give a expletive who you are, and no one else does...
EDIT: since when did HT turn on word filters??!
what kind of work was done to the motor internally?....
sounds like the EXACT same scenario one of my buddies is in....im guessing its rings...good luck man, and keep us updated
Old Oct 9, 2005 | 08:55 AM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: ACT OF GOD!!!!!!! (hondabum4life)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted Chemist &raquo;</TD></TR><TR><TD CLASS="quote">what where u tuning it with? what did your timing look like?</TD></TR></TABLE>
Stock ecu with the VAFC (poor mans hondata)
Anyway, think I'm just going to sell my setup and put out the cash for an H swap
Old Oct 9, 2005 | 09:09 AM
Anyway, think I'm just going to sell my setup and put out the cash for an H swap</TD></TR></TABLE>
idk how accord timimg maps run, but i know the vafc wtih turbo = mad timing. thats why it pulled nice, thats why it died. Before you run the car wtih the new motor, you might wanna look into crome, its a freeware similar to hondata and will make your motor last longer than this one.
Good luck
Old Oct 9, 2005 | 10:21 AM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: ACT OF GOD!!!!!!! (Boosted Chemist)
Good luck </TD></TR></TABLE>
Been studying up on Uberdata and basic tuning. The only guy we have here in JVille that can tune UD is a crackhead that I wouldn't trust with filling my blinker fluid But, I'm probably just going to sell the whole setup and go with an all-motor H. Don't wanna leave the darkside but n/a is so much more reliable
Old Oct 9, 2005 | 10:22 AM
AspectIndustries's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondabum4life &raquo;</TD></TR><TR><TD CLASS="quote">you are Fu&lt;king with the wrong person on HT dude, cease and desist!!!! you are a noob and you dont know that your barking up the wrong tree
just a clue look at his post count! yours 26 mine 163 his 5382 </TD></TR></TABLE>
Post counts dont mean ****. I could sit here and bump threads all day.
