go from a dx to a si ?'s
Old Oct 8, 2005 | 05:21 PM
sk8erracerguy's Avatar
Default go from a dx to a si ?'s
ok so this engine's going out on me so my really koo friend;s gonna let me have his old si engine. I bought the si hardness and now people are telling me that i need this other connection because the hardness wont just plug in. As you can tell im new at all of this so if you guys can help me out on this.PM if u have any info on this.thanx alot
Old Oct 8, 2005 | 05:24 PM
RA122324's Avatar
rywire.com
Old Oct 8, 2005 | 05:28 PM
e jay one's Avatar
Default Re: (knwldge54)
you could wire it yourself search mpfi. you have to convert your dx engine harness to use 4 injectors.
Old Oct 8, 2005 | 06:19 PM
CRXBart's Avatar
Default Re: (e jay one)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by e jay one &raquo;</TD></TR><TR><TD CLASS="quote">you could wire it yourself search mpfi. you have to convert your dx engine harness to use 4 injectors.</TD></TR></TABLE>
Yeah it isn't hard I've done it atleast a dozen times.
Old Oct 8, 2005 | 09:00 PM
Default Re: (CRXBart)
hey do u think u can give me some tips on how to do it, cause i dont know noone that can acctually do it.or if u know a place that would tell u the directions that would b nice.thanx
Old Oct 8, 2005 | 09:52 PM
StorminMatt's Avatar
Default Re: (sk8erracerguy)
Whatever you do, DON'T try to swap the complete SI harness. This is the hard way.
Old Oct 8, 2005 | 10:05 PM
Default Re: (StorminMatt)
so theres an easier way??? cause one of my friends wants to do that but i wasnt sure about it
Old Oct 9, 2005 | 04:21 AM
MUCH easier is to keep the DX hareness and make changes where necesary (ie adding wires for adfditional injectors, etc.).
Old Oct 9, 2005 | 04:25 AM
k91's Avatar
k91
Default Re: go from a dx to a si ?'s (sk8erracerguy)
Do this http://effinmotorworks.com/Effin_MPFI_swap.htm
Old Oct 9, 2005 | 01:09 PM
thanx u guys u guys really help me here
Old Oct 10, 2005 | 07:55 AM
Muckman's Avatar
Moderator in Chief
I swapped a MPFI Si engine into a DPFI CRX. I dont see why you guys say it needs all this fancy wiring if you just swap the engine harness, dash harness and ECU. Thats essentially all the guts from the Si donar car.
For some reason the fuel pump and gauges dont work but the car runs fine when we hard wired the fuel pump. Maybe this type of swap is related to my problems. Does anybody have any ideas?
https://honda-tech.com/zerothread?id=1397689
Old Oct 11, 2005 | 05:09 PM
one of koolest friends gonna help me out and he saids its better if i make the whole car si...hes thinking about changing the interior wiring and the ecu and the fuel pump and well mostly verything... what do u guys think???
Old Oct 11, 2005 | 07:26 PM
aaronhume's Avatar
too much unneccesary work for what you get out of it. just do the mpfi conversion on your dx harness and you will be fine.
Old Oct 11, 2005 | 11:19 PM
NikoZai's Avatar
Default Re: (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">I swapped a MPFI Si engine into a DPFI CRX. I dont see why you guys say it needs all this fancy wiring if you just swap the engine harness, dash harness and ECU. Thats essentially all the guts from the Si donar car.</TD></TR></TABLE>
From the horses mouth : That's the worst way
It's much easier to do a DPFI to MPFI conversion on the DX harness if you know what you're doing. And if you don't, for $160 you can have it done for you. Which is worth the time if you're busy, and certainly worth the troubleshooting if you don't quite understand what you're doing.
Old Oct 12, 2005 | 07:42 AM
Muckman's Avatar
Moderator in Chief
Default Re: (NikoZai)
I dont see how you guys can say its more work. If your doing an entire engine swap, swapping the engine and dash harness is not much harder. Running new wires and re-pinning **** leaves alot of room for error especially for the novice.
My way is plug and play.
Old Oct 12, 2005 | 08:13 AM
SiMateoAko's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">I dont see how you guys can say its more work. If your doing an entire engine swap, swapping the engine and dash harness is not much harder. Running new wires and re-pinning **** leaves alot of room for error especially for the novice.
My way is plug and play.</TD></TR></TABLE>
changing the DX harness to MPFI takes about one hour. You change around about 4 wires and you're done. Changing the engine harness requires you to take the dashboard apart, unattach every connection, get a new instrument cluster (as the SI cluster is different) or you can just rewire your existing cluster to work.
You tell me which one sounds easier. Change four wires, or unhook every connection on your harness, including the zipties and those damn little plastic things that hold the harness in place that NEVER come off without cutting them. If you do the DPFI-&gt;MPFI conversion you just swap it in, one two three.
FYI, you're going to have to change the ECU anyway if your'e going to MPFI. you'll also need a new distributor, and the injector resistor box.
Here's a how to:
http://www.gutterslide.com/fou....html
Don't feel that you have to do the SI harness just because you already own it. You can easily sell that crap on ebay.
Old Oct 12, 2005 | 08:24 AM
virginia_dude's Avatar
Default Re: (SiMateoAko)
Its more than 4 wires....you need to run two extra injector wires to the ECU and all of the injectors to the resistor pack...but its not that hard if you take your time and carefully doublecheck everything each step.
Old Oct 12, 2005 | 11:15 AM
NikoZai's Avatar
Default Re: (virginia_dude)
Well typically you're going to pay $100+ for a whole uncut CRX Si chassis harness on ebay, or a junkyard, and it must match your year (88/89-91) not to mention if you got a hatchback harness instead of a CRX harness, it will never work.
You just don't know for sure when buying harnesses on ebay...
OR
You would leave the junkyards after spending a few hours pulling it, spending $50+ at the door, then having to go home and install it. Not to mention how beat up junkyard cars are, you'll probably have a cut in that harness somewhere.
sure sounds like $160 is the way to go.
I argue my point because i don't want people to start thinking it's easier to install a Si harness, i have countless customers calling with CRX/Civic's that cut out their DX interior harnesses because "they didn't think they needed it" - low and behold, the SI harness they got, doesn't match their model and they have to start from scratch. These are the people that never get their car running and sell it eventually. I don't want to hear any more horror stories based on misinformation they heard online
DPFI to MPFI is so well documented, because it's the better way.
Where's the "replacing your DX chassis harness with a Si chassis harness" Write-up??
Old Oct 12, 2005 | 11:26 AM
Suck my DX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NikoZai &raquo;</TD></TR><TR><TD CLASS="quote">Well typically you're going to pay $100+ for a whole uncut CRX Si chassis harness on ebay, or a junkyard, and it must match your year (88/89-91) not to mention if you got a hatchback harness instead of a CRX harness, it will never work.
OR
Where's the "replacing your DX chassis harness with a Si chassis harness" Write-up??</TD></TR></TABLE>
its not like i had a choice...the car i bought is a dx and the chassis harness was hacked beyond repair...i just happened to find an si chassis harness....the harness needed to be swapped anyway...so why not already go for one that had mpfi wired into it from the factory
Old Oct 12, 2005 | 06:57 PM
jccrxtuner916's Avatar
i just did that same with my 88 dx u will have problems with the dash plug the si ne has i think 17-19 wires going to the dash and the dx has only 11-12 so u will have to pin the out and match the ones that u will need so ur dash still get at least gas, temp and rpm's readings.... u will end up with about 6 cables that u wont fidn a place for,,, not to mention that ur flasher and turn signals will have to be rewired or jsut get the plugs from the si at the junk yard.... im still on the process of finishing up my swap (b16a) and it really gets a lil complicated trust me.... but u will get it jsut put some time into it...
Old Oct 12, 2005 | 11:28 PM
doublethink's Avatar
take out the dx harness and send it out to rywire, or hasport.
or do it yourself. that guide that was posted is very complete...
Old Oct 14, 2005 | 09:36 PM
bch5428's Avatar
the chassis harness replacement is a cake walk.. took me probly 20 minutes and solved two months worth of problems for me.
415Hatch
Jun 7, 2005 04:04 PM
unlimited6986
Jun 6, 2005 04:36 PM
Bad89rex
Apr 22, 2005 06:09 PM
P h i l
Feb 1, 2005 02:52 PM
89 CRX SI
Nov 8, 2002 10:05 PM
