90 crx dash into 91 hb
Old Oct 8, 2005 | 03:42 PM
c0nspire's Avatar
Default 90 crx dash into 91 hb
after searching and reading a little bit i have just a couple questions
what do i need? my understanding is that i need the dash, center console, and bracket (??) can somebody explain to me or show me a picture of what bracket this is exactly?
other than that is it a pretty straight forward swap? everybody bolts into the same spot providing i changed that bracket?
ohh is that the metal cage that your headunit bolts into?
Old Oct 8, 2005 | 04:03 PM
sohc hatch's Avatar
Default Re: 90 crx dash into 91 hb (c0nspire)
It's a straight swap. If I had my digi I take a picture but my sister took it to orlando these weekend. The bracket that they are talking about is the one that the center console piece is bolted to which is bolted onto the chasis of the car. It's right smack in the center when you take the center console piece of - you can't miss it. Good Luck. Looks GREAT !
Good Day,
RH.
Old Oct 8, 2005 | 04:08 PM
c0nspire's Avatar
bronze in color??
is it this one??
this is my car, i had to hack it to make some stuff fit...
Old Oct 8, 2005 | 08:11 PM
SomeDude56's Avatar
Default Re: (c0nspire)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by c0nspire &raquo;</TD></TR><TR><TD CLASS="quote">bronze in color??
is it this one??
that uncracked climate control makes my pants feel funny
Old Oct 8, 2005 | 08:18 PM
c0nspire's Avatar
thanks, took me a while to find it..
Old Oct 8, 2005 | 08:24 PM
c0nspire's Avatar
here is the front of mine with the console... uhmm wait.. i think i might have made a new heater control face plate. or spent a lot of time at the autowrecker looking thru the crx's for one.
Old Oct 9, 2005 | 04:40 AM
SETI20's Avatar
That console is real nice... more pics of how you made it, and how you attached the radio and control unit?
Old Oct 9, 2005 | 05:38 AM
c0nspire's Avatar
it was pretty easy, got a peice of 3/8 plastic.. urathayne i think it was (ill hafta check),
in the back i made releive cuts and heated it and bent it to get the shape. The stock center console was cut afterward to fit the "plate"
The headunit sits in a u shaped tray that was plastic welded to the plate.
The company that did the plastic welding is called BARR plastics, or e-barr
http://www.e-barr.com
the local one here did it as a side job, cost me 20 bucks CAD
Since they mainly fabricate poly tanks for boats its very strong, i can apply a lot of force and the unit will not even flex. Holds the deck very securly.
The climate control is recessed in the plate, altho if i wanted to i could have remoced the front cover (the one that always cracks) and cut out the slots and temp circle from my plate, i chose to do it like this however. It is held on with clips that use the same idea as the gauges.
I do a bad job of explaining, i read this and it sounds funny to me.. Any specific questions im sure i could easily answer
anyways here are the pictures.
you can see the cut away in the console here
Old Oct 9, 2005 | 05:40 AM
c0nspire's Avatar
ohh and btw.. those 2 holes at the bottom
both are cigarette lighters, 12vfully functional. one for a laptop and the other for my cel phone
Old Oct 9, 2005 | 05:45 AM
delguy's Avatar
nice work
Old Oct 10, 2005 | 04:01 AM
c0nspire's Avatar
Default Re: (delguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delguy &raquo;</TD></TR><TR><TD CLASS="quote">nice work </TD></TR></TABLE>
thanks
Old Oct 10, 2005 | 06:21 AM
beyondspexj's Avatar
that is sexy. similar to what i wanted to do. now i actually have a visual to work off of.
Old Oct 10, 2005 | 12:45 PM
c0nspire's Avatar
Default Re: (beyondspecs_jamar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beyondspecs_jamar &raquo;</TD></TR><TR><TD CLASS="quote">that is sexy. similar to what i wanted to do. now i actually have a visual to work off of.</TD></TR></TABLE>
E-Town4229
Aug 30, 2010 04:17 AM
west nile
Oct 24, 2005 04:04 PM
EF ridah
Jul 22, 2004 09:25 PM
White95CivicSi
Mar 27, 2003 12:38 AM
Hayasa15
Jan 13, 2002 03:51 PM
