mechanical oil temp gauge installation
Old Mar 4, 2002 | 03:29 PM
FusionITR's Avatar
Default mechanical oil temp gauge installation
anyway of doing this w/o drilling a hole in your oil pan?
Old Mar 4, 2002 | 03:34 PM
sgT's Avatar
sgT
Default Re: mechanical oil temp gauge installation (FusionITR)
you can put it in the head.
Old Mar 4, 2002 | 03:35 PM
Mike M's Avatar
Founding Member
Theres a plug in the Cyl. Head near the passengers side above the Intake Manifold, not sure how far off it will be from Oil temps in the pan though.
PS - Thanks to Steve
Old Mar 4, 2002 | 03:36 PM
FusionITR's Avatar
Default Re: mechanical oil temp gauge installation (sgT)
hrmmm....
where is the easiest place?
Willard's Avatar
Yes...
If you can find a sending unit that is built like a drain plug...
try the VDO web site. http://www.vdona.com/aftermarket/aftermarket.html
Will
-who's old Volvo had a drain plug sending unit...
Old Mar 4, 2002 | 03:37 PM
FusionITR's Avatar
Default Re: mechanical oil temp gauge installation (TypeRmsm)
where exactly? can u provide pix?
Old Mar 4, 2002 | 03:38 PM
Willard's Avatar
fyi.. oil temps = sending unit must contact oil
Will
Old Mar 4, 2002 | 03:41 PM
Mike M's Avatar
Founding Member
Steve told me about it when I asked him about another spot other than the pan, I havent installed mine yet. So No pics
FusionITR's Avatar
Default Re: mechanical oil temp gauge installation (Willard)
easiest way without buying anything....
Old Mar 4, 2002 | 03:42 PM
FusionITR's Avatar
if i can provide pix after i get home from work will u be able to point it out to me?
Old Mar 4, 2002 | 04:53 PM
cyan1de's Avatar
http://www.theoldone.com/articles/oilpressure/
this is how us turbo guys like to do it:
Old Mar 4, 2002 | 04:57 PM
sgT's Avatar
sgT
Did you say MECHANICAL OIL TEMP???
Oh man, return it and get electrical.
Old Mar 4, 2002 | 05:04 PM
FusionITR's Avatar
Default Re: mechanical oil temp gauge installation (cyan1de)
umm... dude its a oil temp gauge, not oil pressure
Old Mar 4, 2002 | 05:25 PM
cyan1de's Avatar
woops i didn't read that right
Old Mar 4, 2002 | 06:34 PM
primoEF's Avatar
easy, you can use you stock drain plug, first drill a small hole thru thats for the sensor to stick out, then drill a bigger hole and tap it so the sensor can thread into it, also you can buy the drain plug with the hole already in it from Autometer or HKS.
Old Mar 4, 2002 | 07:10 PM
GQ 05YellowEVO8's Avatar
Default Re: mechanical oil temp gauge installation (b18k1)
i need to redo my oil press. gauge too
Old Mar 4, 2002 | 07:57 PM
Raymund's Avatar
New User
"Did you say MECHANICAL OIL TEMP???
Oh man, return it and get electrical."
I second that statement! A mechanical gage measures oil temp away from the engine. the temp is read in the gage itself. without a recirculating oil line your readings will be inaccurate guaranteed. what you want is a temp sensor as close to the oil tap itself.
Old Mar 4, 2002 | 08:04 PM
sgT's Avatar
sgT
Default Re: mechanical oil temp gauge installation (Raymund)
No thats wrong. It doesnt meaure away from the engine.
The autometer mech. temp gauges have a real PITA metal tube that needs to be
routed around. Its sooo much easier to route wire instead.
Old Mar 4, 2002 | 08:16 PM
Raymund's Avatar
New User
ok.. thanks for explaining. but even with a real "PITA tube" where is the actual temp reading taken at with a AutoMeter mech guage?
Old Mar 4, 2002 | 08:49 PM
sgT's Avatar
sgT
Its taken at the source.
Old Mar 4, 2002 | 08:59 PM
b00st-0wnz's Avatar
From: Drinking Beer in sunny FL and jamming to Skid Row, USA
The PITA metal line doesn't contain oil, but glycol (sp?) and maybe some other crap IIRC. Either way, the mech gauge is more accurate than the electrical but is harder to install in your average street car with all that dash board crap in it.. ac vents.. etc.
Old Mar 4, 2002 | 09:01 PM
FusionITR's Avatar
oh, i forgot this thing came with it
is this like a replacement plug i can use then screw the sensor on it?
Old Mar 4, 2002 | 11:00 PM
FusionITR's Avatar
ttt
Old Mar 5, 2002 | 01:17 AM
Bloodwynch's Avatar
If you wanna plug the mechanical temp sensor into the engine block hole near the distributor you need a metric adapter.
5/8" - 18 UNF to M16 x 1.5
Old Mar 5, 2002 | 03:49 AM
DutchITR1689's Avatar
There is oil temp sensor available which replaces the oil dipstick.....
