keyless entry door lock wiring
Old Oct 8, 2005 | 11:52 AM
low_crx87's Avatar
Default keyless entry door lock wiring
I have an arctic start ARC-2001 remote car starter, its all wired works fine, did it myself, now with the keyless entry i have a question, I bought universal power door locks, they have 2 wires, when i put the blue on 12v and green on gnd it pushes out, when i reverse the conections it retracts... my manual for keyless entry says this..
Brown wire (lock) - On cars with Negative Trigger door lock systems, this wire can be attached directly to the wire that unlocks the doors when a ground is applied. For Positive triggered door locks, this wire can be attached directly to the wire that locks the doors when a positive signal is applied.
Green wire (unlock) - On cars with Negative Trigger door lock systems, this wire can be attached directly to the wire that unlocks the doors when a ground is applied. For Positive triggered door locks, this wire can be attached directly to the wire that locks the doors when a positive signal is applied.
So how do i wire this? im a bit confused..
Modified by low_crx87 at 1:20 PM 10/8/2005
Old Oct 8, 2005 | 12:58 PM
fcm's Avatar
fcm
Old Fart
Default Re: keyless entry door lock wiring (low_crx87)
You will need a pr of SPDT relays and wire them like this http://www.the12volt.com/doorlocks/page3.asp#arp you may want to read this also http://www.the12volt.com/relays/relays.asp 94
ryanplayjoint
Audio / Security / Video
11
Apr 4, 2011 04:59 PM
kcjohnnyboy
27
May 10, 2008 08:30 AM
rasinhell
May 10, 2005 09:27 PM
Odessa
19
Aug 3, 2004 06:37 PM
DocYahoo
15
Jul 20, 2002 04:29 PM
