EK SWAP INFO
OK I REALLY NEED SOME HELP WITH THIS AND I'VE CALLED ALL KINDS OF PEOPLE AND NO ONE HAS BEEN ABLE TO HELP. HERE'S WHAT I GOT:
98 CIVIC DX HB AUTOMATIC I WANT TO SWAP A 99 CIVIC EX MANUAL TRANS MOTOR ONLY IN WHAT WILL I NEED TO DO?
If you're only swapping in the motor, then you shouldn't need anything except for the engine harness, unless you wire it up directly to the ECU for VTEC. Just make sure you get the ECU for OBD2a 98 EX auto tranny. Everything should bolt right up. If you're not wanting to cut and splice for your VTEC wiring, you'll need a 96-98 EX engine harness.
If anybody thinks I'm missing something, help this guy out, lol.....
This site will help you a ton with the ECU wiring for vtec, and the IACV Fix.
http://www.ff-squad.com/technet/
I did a similar swap on my car, but actually switched mine from an auto to a manual.. i suggest you do the same
It's not much more work actually, If you're pulling the motor out honestly you might as well. It would only be a couple hundred bucks for the parts needed for a auto>manual swap from a junkyard.
Here's the fix for the IACV, if you retain your 96-98 (OBD2A) Harness. - http://www.ff-squad.com/tech/w...8.jpg
Here's the fix for the IACV if you go with a 99-00 (OBD2B) Harness to match the motor - http://www.ff-squad.com/tech/w...8.jpg
Hit me up if you have any other questions.
It's not much more work actually, If you're pulling the motor out honestly you might as well. It would only be a couple hundred bucks for the parts needed for a auto>manual swap from a junkyard.Here's the fix for the IACV, if you retain your 96-98 (OBD2A) Harness. - http://www.ff-squad.com/tech/w...8.jpg
Dakotat
10
Jan 7, 2013 07:05 AM
jspecPR26
Aug 8, 2005 03:54 PM
