Problem With My Ls Swap..HELP~!!!!!!!!!!!!!!!!!!!!!!!!!!
i just got a 96 LS swap done on my..93 SI Hatch
but for some reason..the
1) RPM is not running on 1000RPM
it runnin prolly around like 500 or lower...
2) Is Not Pulling Up The HP For The Car..( Like When I Push Gas Is Not Going Up )
when it said 40mph..but car doesn't Seen To Be Runnig @ 40mph
please help....... me fix this problem
any cels? (check engine light)??? did you make shure your plugs on your tps,iacv,etc... were plugged in correctlly, you have to be a little more clear about what the car is doing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dorkoftheyear »</TD></TR><TR><TD CLASS="quote">any cels? (check engine light)??? did you make shure your plugs on your tps,iacv,etc... were plugged in correctlly, you have to be a little more clear about what the car is doing.</TD></TR></TABLE>
Bump cause i'm having the same problem, my CEL has the IACV,TPS, and fuel injector code?? i'm sure i plugged them in specific order and fitted perfect. H-t help!!
check all plugs..again. Also is the timing correct sometimes there is a power loss with that. the idle may be iac or tps....could be bad
yea..my o2 sensor is broken..so well that cosh the problem of the speed??
i dont know much about car that's why..i'm a NOOB...so i'm tryin to learn...
