96-98 civic foglight question
Old Oct 7, 2005 | 06:27 PM
o d i e e's Avatar
Default 96-98 civic foglight question
ok here's the deal. i've had these fogs on for a while and they never failed me. but recently they began to act up. at first they wouldnt turn on so i jsut kept pressing the button till they did turn on., which eventually they did. since then i havent been able to get them back on. i checked all wiring and made sure nothing came loose or unplugged and re-did everything at that also and still nothing. granted these are replica fogs but should they go out so easily? maybe the bulbs jsut went out? has anyone had any problems with these? wiring or anything else? any help is greatly appreciated.
Old Oct 8, 2005 | 01:33 AM
BlueIntegraBoy's Avatar
Default Re: 96-98 civic foglight question (o d i e e)
Is your relay clicking? Check bulbs
Old Oct 8, 2005 | 08:30 AM
o d i e e's Avatar
Default Re: 96-98 civic foglight question (BlueIntegraBoy)
yeah my relay clicks. most likely bulbs? shouldnt they last longer?
Old Oct 8, 2005 | 10:36 AM
chinese acrobat's Avatar
Change bulbs and turn them on again. Still have the problem? go through your wiring again take your time.
Old Oct 8, 2005 | 10:37 AM
pdiggitydogg's Avatar
do you have any leaks in the housings? what wattage bulb are you using?
Old Oct 8, 2005 | 11:56 AM
kkim's Avatar
Get a voltmeter and check to see if you are getting 12v to the bulb socket when you have them on. If you are, bulbs are the problem, if not, start working your way back until the 12v appears.
Sure you don't have a bad switch?
Azavala
Apr 8, 2016 02:14 PM
tei344
Mar 7, 2008 05:36 PM
redrelease
Mar 1, 2007 01:12 PM
bboysake
Jan 23, 2007 08:54 AM
eg8000rpm
Apr 27, 2005 12:37 PM
