had a b16a now i want an LS. how hard is the swap?
Old Oct 7, 2005 | 03:31 PM
the.hamburglar's Avatar
Default had a b16a now i want an LS. how hard is the swap?
i blew the b16a after a summer of boosting and i dont really want to buy another one because they are alot more money than an ls block. how hard is the swap from a b16a to an LS? does anyone know if all my custom turbo parts will bolt up meaning my intercooler pipes and custom downpipe? what wiring needs to be done? thanks
Old Oct 8, 2005 | 08:06 AM
Default Re: had a b16a now i want an LS. how hard is the swap? (the.hamburglar)
ttt
Old Oct 9, 2005 | 03:44 PM
some has to have done this before?
Old Oct 10, 2005 | 06:36 PM
EGDC2CIVIC's Avatar
just pull the b16 and put the b18 back in. you will want to run the b16 tranny though, im not 100% sure on the turbo parts but they should still fit the same
Old Oct 10, 2005 | 06:58 PM
HomeDepotMade's Avatar
Default Re: had a b16a now i want an LS. how hard is the swap? (EGDC2CIVIC)
well u can just pull out the b16 and drop the ls in. it should be a direct drop in. and keep the ls tranny if ur boosting.
Old Oct 10, 2005 | 07:27 PM
Default Re: had a b16a now i want an LS. how hard is the swap? (Hype Vtec)
i have a b16 lsd tranny. im using that
Old Oct 10, 2005 | 07:28 PM
there is no other wiring i have to do? the vtec wire?
Old Oct 10, 2005 | 09:03 PM
Taristin's Avatar
B18B's (LS/RS/GS/SE) are non-vtec... so there's no vtec wiring...
Old Oct 11, 2005 | 07:37 AM
Default Re: (Taristin)
yeah i know, but i have a vtec wire from the b16. just cut it?
Old Oct 11, 2005 | 04:40 PM
EGDC2CIVIC's Avatar
Default Re: (the.hamburglar)
no just leave them in there they wont hurt anything
Old Oct 11, 2005 | 05:27 PM
tegasaurus's Avatar
Default Re: (EGDC2CIVIC)
make sure you run the LS ecu or you'll throw codes.
Old Oct 11, 2005 | 08:33 PM
Default Re: (tegasaurus)
what about a chipped p28 with a stock ls rom? same thing
Old Oct 12, 2005 | 07:05 AM
mattssi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the.hamburglar &raquo;</TD></TR><TR><TD CLASS="quote">what about a chipped p28 with a stock ls rom? same thing</TD></TR></TABLE>
you'll be fine then. You may need a differen't rear mount. Other than that, It should drop right in. I may be wrong about that though. Just leave the wiring the same
desii
17
Jan 25, 2008 10:36 AM
llansy
Oct 29, 2007 11:29 AM
bbrian
95
Jan 26, 2005 11:04 PM
acuradriver4
May 29, 2004 09:56 PM
94civic_EX
Sep 4, 2003 08:44 PM
