what ECU do i need? (OBD1 B16A2)
Old Oct 7, 2005 | 02:43 PM
RACEPAK's Avatar
Default what ECU do i need? (OBD1 B16A2)
hello everybody.
can somone please tell me what ecu's will work perfect on a OBD-1 B16A2 engine?
THANKS
p.s, dont flame.
-can i use sohc ecu on a dohc engine?
Old Oct 7, 2005 | 02:46 PM
SkRiBLaH's Avatar
Default Re: what ECU do i need? (RACEPAK)
OBD1 P30
OBD1 P72
you can use a SOHC ecu but it will run VERY VERY VERY lean for a b series
ek_99_SiR's Avatar
u could use a p72(gsr) or buy reza's p73(type r)
Old Oct 7, 2005 | 02:47 PM
kchungb17a's Avatar
You can use DOHCVTEC del Sol ECU's up to 1995. Not sure what the code is on that one. Also the P61 from a 92-95 GSR will work but those are ultra rare. You can also use chipped ecu's but then the programming is always questionable. If you're in a jam you can use SOHC ECU's (P05, P06) and even LS ecu's (P28) but you wont' get any VTEC action. That's pretty much just to get you moving if you you can't find the right ECU.
Old Oct 7, 2005 | 07:03 PM
hatchi's Avatar
chipped p28, obd1 p30
Gavin G
11
Jul 4, 2014 12:02 PM
1sikhatch
13
Sep 29, 2007 06:01 PM
cyrock
Jun 25, 2006 01:29 AM
blackie
Jul 10, 2005 03:38 PM
91hatch_on17's
Oct 27, 2003 02:35 PM
